Engine malfunction-'23 Prius LE - 3700 miles
Discussion in 'Gen 5 Prius Main Forum' started by Argyros, Sep 19, 2024.
  1. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    I was driving to a client today, and at a stop sign suddenly, BING BING...Engine malfunction, limp mode, visit dealer immediately. Non prime here.
    Just had the doors recall last Saturday and had no issues over the last year.
    No idea what could've caused this, but it's at the dealer now, towed, and probably there for a while...at least my dealer had a loaner car free while it's in the shop.
    Any ideas of what could be happening? Could it be related to the recall?
  2. Hammersmith
    Hammersmith Senior Member
    2,491
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Related to the recall? No. I don't think it could be related even if the tech managed to damage some random wire while doing the work. There's just nothing going to the rear doors that could cause an engine malfunction. I guess I'd be more willing to believe a screw up while doing the regular service versus anything to do with the recall.
    I wish you would've had a code scanner to see what codes were thrown before the shop took over. Without that info, there's no way to know if this is a mechanical problem, an electrical problem, or something else altogether.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    There have been instances of such malfunctions reported here, which are common in new redesigns. Check the several threads on such instances here. Hopefully by the 2026 model year, these bugs will have been fixed. And report here what the dealer finds.
  4. Argyros
    275
    142
    2023 Prius
    Ok. Bad news- turns out there were rodents eating the electric cables, and caused almost $ 600 worth of damage; has anyone had that happen to them? I spoke to the dealer service rep, who told me I need to put 'MOTH BALLS' in strategic places in the engine bay, which will repel the rodents from doing that again. I can confirm where I live, due to the 100+ degree heat, there have been alot of rodents, yet my car was just at the dealer service last Saturday and they said it would have happened between then and today. Dammit!
    Gokhan likes this.
  5. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah because the wiring harness uses soy-based plastic, which rodents like to eat. Best option is to make friends with neighborhood/stray cats. They'll keep rodents, squirrels and anything else that likes to eat the wiring harnesses away.
  6. bisco
    52,860
    been happening to prius forever, and other cars. consider yourself lucky, some cars have been totaled by rodents
  7. Hammersmith
    2,491
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Or you could own a Mercedes from the late-90s/early-00s(I think that was the timeframe) where the wiring harnesses were not only tasty to rodents but also biodegradable. And they misjudged the rate of degradation. It's fantastic to have the harness completely fall apart in just under 20 years. /s
  8. Argyros
    275
    142
    2023 Prius
    So what are the options to keep the rodents out of the engine bay?
  9. bisco
    52,860
    cats, traps, peppermint, screening off entry points
  10. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    Glad I live at 8800'. Not too many rodents and winter is coming...
    Maybe wrap wiring with something that isn't attractive to rodents?
  11. Argyros
    275
    142
    2023 Prius
    Used peppermint packs gauged at repelling rodents...miss my new car smell, and smells like toothpaste but no rodents is better
  12. reservoirblue
    reservoirblue Member
    96
    76
    Woodacre, CA
    2024 Prius Prime
    SE
    We have had some success with high frequency sound devices in the attic. You would need to plug it into 120v.
  13. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    1 mouse trap in front of each front wheel, especially in fall and winter. I would find them in the air cleaner as well. I would usually catch about 1-3 a week in ea trap for the 1 st month or so, then 1 a month. If it's in a garage, check your garage door bottom weatherstrip. I found they can chew through it looking for a place that is warmer going into winter. If they did chew, stuff steel wool in the opening where they got in. Their tummys don't like that. ;-). If you store bird seen in the garage they go for that as well.
