Engine mode when EV is selected
Discussion in 'Prime Main Forum (2017-2022)' started by andrewe2, Jan 19, 2023.
Tags:
  1. andrewe2
    andrewe2 Junior Member
    24
    I have a 2021 Prime and occasionally, when EV mode is selected with a full charge it stays in engine mode until I turn it off and back on. Then it runs off the battery. The weather is never very cold or hot? Anyone else experiencing this?
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    There are things that will cause the gas engine to run. Merely running the defroster can do it. Once the internal combustion engine (ICE) starts it will run until it’s warmed up. There are lots of discussions on this topic.
    52,863
    when you start the car, it should be in ev mode, unless you chabge it to hv or auto. or id any of the things schja01 mentions bove
  4. Tideland Prius
    16,681
    Are you driving in B mode? You should be in D.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    It's never a good idea to manually shut down the ICE in a Prius while it is still running. The computer has decided the engine needs to be running, and you're better off letting the computer turn it off before powering down the car. Usually, the ICE needs to complete its warmup before it should be shut down. Just select Park, turn OFF the HVAC (engine could be running to provide cabin heat) and let the computer shut off the ICE--then Power down the car down. Not letting an ICE achieve full operating temp will leave unburned hydrocarbons (fuel) in the oil and excess water vapor in the exhaust system. Both are bad for the longevity of the car.
  6. bisco
    52,863
