Engine mounts…location of/inspection of
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Sep 11, 2023.
  1. qdllc
    qdllc Senior Member
    1,371
    399
    2013 Prius. Sometimes I get an odd noise when the ICE kicks in. I want to check if there is an issue with my engine mounts. I know the mounts can be good and there still be noise.
    51,155
  3. Mendel Leisk
    40,586
    Attached is the full engine section. I believe around 115 page engine mount info starts, but look around too.
  4. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Sometimes your symptoms are caused by a failed headgasket... If you open your coolant reservoir and hear air sucking in as it opens that confirms this is the cause of your symptoms.
