engine noise if stuck in traffic
Discussion in 'Prius v Main Forum' started by Karen E, Dec 1, 2012.
  1. Karen E
    Karen E Junior Member
    Just cking..if I am in a traffic jam..I notice after awhile there is a shift in the engine and I don't get good mileqage anymore until I am out of traffic..what gives??
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    The ICE (ie the gas engine) is started to charge the traction battery when the battery charge gets below a set level. The engine then runs at a higher speed until the battery charge level is increased. This happens because you were probably creeping along using only the battery when stuck in traffic.
    Karen E likes this.
  3. parnami
    parnami Member
    227
    47
    .Lancaster, PA (Amish Country) :)
    Or...it's cold outside and the engine turned on to provide you with heat. I wish you'd list where you live.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep.
    OP, do you have a Prius v wagon?
