Engine Noise - Only when accelerating.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by heavenscoins, Jan 12, 2016.
  1. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thank you I took it to a garrage and it looks like the honeycomb inside the catalytic converter was rattling and causing the air not go get out quick enough. Would you recommend cleaning the egr valve and pipe too
  2. dolj
    dolj Senior Member
    8,655
    4,406
    Wellington, New Zealand
    No. The Gen 2 does not have those. You might consider cleaning the PCV valve though but I would bother myself unless you have reason to believe it is sticking.
    iron-icman likes this.
  3. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thank you this code did come up on my reader with the Prius app p0420 not too sure what it could be with me getting the cat changed
  4. dolj
    dolj Senior Member
    8,655
    4,406
    The CC installed is not good enough. Presume it is not an OEM CC.
    maleko likes this.
  5. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    So will it still be ok to drive if I just clear the codes
