Engine Noise: Weird!
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Jul 24, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    After all this time almost entirely on EV (other than a couple of road trips), I had to burn some gas today -- perhaps a little over a gallon. 3/16 tank now.
    I'm happy to report that it's really weird to hear the engine whirring, and that I'd forgotten what a P.Prime engine sounds like!
    iPhone ? Pro
  2. bwilson4web
    16,519
    Drive faster and you won't notice the engine. <GRINS>
    Just don't ignore the sirens.
  3. DavidA
    2,349
    1,825
    Chicago western burbs
    Gas? What is this "gas" you speak of? More info please, and pictures. Pictures always help.
    mr88cet likes this.
  4. mr88cet
    2,313
    1,335
    Austin, TX
    Next time you plug in, take a look over on the left-rear fender of your 'Prime: There's something that looks like a second charge-port door over there! This one's different though: Instead of plugging in, you put a stinky, poisonous, flammable, carcinogenic liquid into that left-side charge port.
    That stuff is called "gas," even though it's a liquid. Maybe it's made from intestinal gas, and that's why it stinks so much...
    Little-known fact: the 'Prime has a bulky, complicated, noisy, heavy, and maintenance-intensive machine in the front that burns gas! The resulting smoke stinks a lot less, so I guess it must be there to make this dreadful-smelling liquid less stinky.
    You can buy this "gas" at most convenience stores. It's sold outside in dank, dangerous corners where creepy strangers hang out at night.
    iPhone ? Pro
    #4 mr88cet, Jul 25, 2017
    Captmiddy and ComaJoe like this.
  5. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    I just turn the radio up.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    ok, here ya goh
  7. DavidA
    2,349
    1,825
    This all helps. I found some sort of doorway or panel on the back left fender of my car. If that isn't for charging when my car is in my driveway the other way around, then I guess it might be for this gas stuff. I'll be darned if I can figure out how to open that little hatch. I've tried pounding on it. Nothing. :confused:
    priuscatprimeguy likes this.
  8. priuscatprimeguy
    2,730
    2,640
    Use a screwdriver to pry it open:p
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    As an owner operator of a full ICE vehicle, I'd just like to say, quit showing off.
  10. mr88cet
    2,313
    1,335
    Austin, TX
    It's an aerodynamic speed brake, like on the Space Shuttle.
    iPad ? Pro
    Prius from Dad likes this.
  11. priuscatprimeguy
    2,730
    2,640
    :mad::mad::mad:
  12. 1x1
    1x1 Member
    147
    45
    It's two cars in one - and I know which one I prefer.
  13. huskers
    2,548
    2,488
    Nebraska
    I think that is one of those storage hiding places.
  14. DavidA
    2,349
    1,825
    Maybe I can store gas behind there in case I ever need it?
  15. mr88cet
    2,313
    1,335
    Austin, TX
    As I described earlier, I think it's a setup to make gasoline less stinky. Probably just as a community service. There's a complex machine under the hood for that purpose, it appears...
    iPhone ? Pro
  16. DavidA
    2,349
    1,825
    Found it! It is actually in the owner's manual. Reading is hard! So it turns out there is a button on the bottom left of the dash that, when pushed, opens the hatch on the back left fender. Says that's where the gasoline goes in, and to not overfill it. I don't know if, or when I might need to open it up, but the owner's manual covers that too. When the little yellow line is short to the left, it needs gas.
    I covered the button up with some black gaffer's tape, just for good measure. Stupid button!
  17. mr88cet
    2,313
    1,335
    Austin, TX
    Are you sure it's not a speed brake for dive-bombing runs?
    https://www.google.com/imgres?imgurl=https%3A%2F%2Ffarm9.staticflickr.com%2F8671%2F15349169153_18d69a7e20_b.jpg&imgrefurl=http%3A%2F%2Fpicssr.com%2Ftags%2Fspeedbrake&docid=XuJAuAd5NgcuJM&tbnid=AfN6O6EpQpmZeM%3A&vet=10ahUKEwiO38qu87XVAhVMTSYKHXEMBF8QMwg9KAUwBQ..i&w=1024&h=683&hl=en-us&client=safari&bih=628&biw=414&q=speed%20brake%20on%20f86&ved=0ahUKEwiO38qu87XVAhVMTSYKHXEMBF8QMwg9KAUwBQ&iact=mrc&uact=8
    iPhone ? Pro
