Engine noise
Discussion in 'Gen 2 Prius Main Forum' started by Ron63, Aug 26, 2020.
  1. Ron63
    Ron63 Junior Member
    West Jordan Utah
    My 2009 Prius has a knocking noise when engine at operating temperature...only occasionally..most of the time its quiet. It does it under acceleration and very audible inside the car. No engine lights are on and everything is working fine otherwise. Does anyone have an idea what it might be? Thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,284
    5,366
    Pacific Northwest, USA
    Is your gas mileage ok? Does engine power seem less or unchanged?
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Is the engine oil l correct? Has it been very low at some point?
    If it's only rarely it could be misfiring but not often enough that it would set a code. You could check misfire monitor wirth scan tool to check this. New plugs or coils would probably fix that.
    If it's pinging you could try higher octane fuel. If it would stop if it was that.
  4. Ron63
    Ron63 Junior Member
    West Jordan Utah
    Yes it gets great gas mileage and the power is unchanged
    Yeah I made sure it had the correct oil in it and I checked it...it was still full I'm wondering about the octane of gas for it...Utah regular unleaded is 85 octane...may be too low
    #4 Ron63, Aug 27, 2020
  5. Ron63
    Ron63 Junior Member
    West Jordan Utah
    I might also put new plugs and coils in it...I know the former owner took good care of it and always had dealer service done to it...I bought the car about a year ago..I believe the maintenance book said the plugs and coils were replaced about 12,000 miles ago
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Wish I knew why no one can post the miles on there car on this CAR FORUM.
    But always having the dealer do its service is a death sentence to the engine. Thats why the engine is knocking. Its got a blown bottom end.
    It ran out of oil because the previous owner never checked it. Why should he its DEALER maintained!
    I never have to open the hood whoopie!
    Because the dealer never checks it when the car rolls in. they just dump it then over fill it with the worlds crappiest oil.
    And now its a heavy oil eater.
    2 reasons why people sell there G2 and most have the same 2 and that's bad hybrid battery and engine eats alot of oil.
    man we see this over and over and over again.
    Do this join this website:
    toyota.com/owners
    Have your insurance card handy as it will ask you for the cars vin. When joined you can see every single time the car has seen an authorized toyota dealer for service and what they did to it. You may find out why the car was sold.
    PriusCamper and Aaron Vitolins like this.
  7. ttou68
    ttou68 Active Member
    351
    211
    Just a thought, check engine water pump..
    The bearing maybe going bad, hence why you only hear it occasionally.. if bad, you will hear it all the time... But, just a thought..
  8. Ron63
    Ron63 Junior Member
    West Jordan Utah
    I signed up....shows just regular maintenance performed...front brakes replaced about 8,000 miles ago. It showed 153,000 miles on it when the previous owner last maintained it...I got it at 154,000
  9. edthefox5
    10,096
    4,836
    Clearwater, Florida
    Ok good.
    We see so many big estimate at the dealer vehicles here the guy then turns around and sells it. Especially with the hybrid battery's failing left and right now.
    Go on youtube and search
    prius Inspection
    it will show you how to put the car in inspection mode and then engine will idle continuously until you shut it off giving you a chance to listen to it. Both top and bottom. This requires some experience with engines so don't know your level of diagnosis.
