Engine O2 sensor values on ODB2 reader
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by satsuke, Nov 7, 2019.
  1. satsuke
    satsuke Junior Member
    68
    When looking at the O2 sensor output, is it expected to have voltage readouts on more than one bank?
    I had thought this engine had two .. one by the catalytic converter and another in the intake manifold.
    I'm looking at the output of an ODB2 reader and only see output on Bank 2, sensor 1.
    My 2012 Prius 3 (190,000 miles) threw a code that the O2 sensor was out of range on Bank 1, Sensor 1 . .but that one has zero output.
  2. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    Bank 1 sensor 1 is the Air/Fuel sensor (or some consider the upstream O2 sensor forward of the catalytic converters)
    Bank 1 sensor 2 is the Heated O2 sensor which is downstream after the catalytic converter.
    Search for my post on P0136 and there is a good discussion on voltages
    Also depends on which app/device you are using to get values. Ultimately tech stream is the best tool for diagnosis.
    -Spiral
