Engine oil grade and replacement frequency
Discussion in 'Gen 4 Prius Main Forum' started by rahmani, Apr 29, 2021.
  1. rahmani
    rahmani Junior Member
    Bangladesh
    What would be the best engine oil grade for Prius 2016?
    What would be the ideal frequency to change engine oil?
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The owner's manual says:
    • 0w-20 (but you live in a hot climate so 5w-30 may be more appropriate)
    • 10k miles (16k km) or one year with full synthetic oil (if using non-synthetic oil I would say 5k miles (8k km) or 6 months)
    JeffD
    Doug McC, amos, rahmani and 1 other person like this.
  3. rahmani
    Bangladesh
    Thanks
  4. Mendel Leisk
    42,343
    Owners Manual might say 0W16 (4th gen rev), but that’s maybe just Toyota trying to eke out a bit more mpg. Still, definitely consider heavier oil in hot climate.
    amos and rahmani like this.
  5. rahmani
    Bangladesh
    Thanks
  6. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mendel,
    There has been a drive to use a new grade of oil, "GR-6B" in cars, but that is for engines that were designed for that oil. A 2016 Prius predates the spec, but Toyota says it is OK. I am sticking to 0w-20 in my Gen4.
    "0W16 oils were going to be part of the ILSAC GF-6 rollout as GF-6B oil. What is significant about GF-6B oils is that the specification will not be backward compatible because of the new viscosity grades."
    JeffD
    amos and Mendel Leisk like this.
  7. Hamza Masarwa
    Hamza Masarwa Junior Member
    35
    Jordan
    Hello
    I need a soft copy of owner's manual plz.
  8. Mendel Leisk
    42,343
    You can download PDF at Toyota Tech Info. And also some Toyota Owners site?
    Doug McC likes this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    It's in the Owner's Manual. Oil Grade is on the Oil Filler cap.
    Doug McC, jerrymildred and krmcg like this.
  10. alanclarkeau
    7,045
    7,593
