engine Oil Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cybervic, Jun 1, 2017.
  1. Cybervic
    Cybervic Junior Member
    East Sussex, UK
    My Prius is 2007, 87000 miles currently, we use it couple time a week for short distance in the city. (doing 8000 miles per year).
    So I have a bottle of Castol Edge Oil (5w-30 Fully Synthetic) that was for my previous car (VW Passat).
    Some online search results are saying Castol Edge 5w-30 is fine for Prius. However, the bottle I have states for Audi, VW, BMW, Mercedes-Benz, Porche, Skoda & Seat Cars, and mention nothing about other make of cars including Toyota.
    So my question is as follows:
    1. Are all Castol Edge oil the same in which I can the bottle now on Prius without causing problem?
    2. Will Prius benefit from frequent oil change @ 5000 miles/6month like other conventional car?
    3. What is usually the best oil for fuel efficiency?
    Thanks.
    Vicky
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Check out
    AMSOIL Signature Series 0W-20 Synthetic Motor Oil
    It's rated up to 25k miles.
    I use it to 30k and my oil tests via Blackstone labs show great!
    SERVICE LIFE
    • Normal Service – Up to 25,000 miles, 700 hours of operation
    or one year, whichever comes first, in personal vehicles not
    operating under Severe Service.
    • Severe Service – Up to 15,000 miles, 700 hours of operation
    or one year, whichever comes first.
    Cybervic likes this.
  3. JC91006
    16,938
    8,647
    The Castro 5w-30 is fine for the prius. Basically any brand oil with that grade is fine.
    Best to stick to the maintenance schedule doing 5000 mile oil changes. Especially when you drive short distances.
    edthefox5 and Cybervic like this.
  4. Cybervic
    East Sussex, UK
    I am based in UK and AMSOIL doesn't seem that popular, looking at past service record (only had the car less than 2 month ago), 5w-30 has been used in the past 7 years though.
    Thank you, I don't know what grade is this bottle of Castrol Edge, how do I tell if it meets Toyota's specification?
  5. Currahee
    Currahee Member
    103
    34
    CT
    The grade is the 5w-30 written on the bottle. Should be the same on the engine oil cap.
  6. windstrings
    6,280
    378
    Central Texas
    I think Amsoil is not super popular because you never see commercials at least hardly ever which in my book is a good sign
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Amsoil like Redline are expensive oils. But I use Redline as it has an excellent zddp package in addition to be pure Esther base stock that really helps the solid lifters. The tappet noise reduction is impressive. It's really the only oil you can use that you will notice a difference in engine begavior.
    But it's expensive at $12 a quart.
    Jegs......free shipping.
    Google Redline oil. Thousands of posts.
  8. windstrings
    6,280
    378
    Central Texas
    Well expensive oil is really the cheapest oil since you can go so much longer between oil changes
  9. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Yes but I like it for other reasons other than it's oci.
  10. windstrings
    6,280
    378
    Central Texas
    In cars with consumptive use you're always adding oil every month to keep the levels up so I expect you could go even longer upwards of 40 k as long as you drive in a clean air area so the oil filter doesn't get taxed
  11. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    1. You can use the oil in the Prius no problem. Feel free to mix it with any other oil that's compatible with the Prius in fact.
    2. A 5000 mile interval is the normal interval for the Prius.
    3. Thinner oil yields better fuel economy. A full synthetic 0W-20 will yield the best fuel economy. I'd follow your user's manual and choose the thinnest grade that it's spec'd for. In the US for the 2nd gens 5W-30 is specified, but I believe for the UK 0W-20 is spec'd, even though it's the same engine (likely due to the differences in weather, and to help avoid liability claims from lazy Americans who don't change their oil often enough). 0W-20 should be great for UK weather, however if you know you're going to be for example driving in Spain in 40C weather, I'd recommend having 5W-30 oil in the car to keep the engine wear down.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    But I would be much more concerned about the hybrid battery health not to mention the 12 volt battery healt. Your driving habit does not bode well for either. Life of short infrequent trips does not fully charge either battery and
    Also could lead to corrosion of the hybrid battery.
    How many times have you had to replace or jump start the 12 volt battery?
  13. nwawolff
    nwawolff Junior Member
    US
    Basically any name brand oil is good. I use Mobil 1, Long Life 15,000 oil and I change at 10,000 miles. 2007 with Epps miles.
    LG-TP260 ?
  14. edthefox5
    10,096
    4,840
    Clearwater, Florida
    To much fuel dilution for me to go 10,000 miles.
  15. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    In the US.
    The standard UK OCI is 10,000 mi or 1 Year.
    Use any 5W-30 fully synthetic that is API SL (or better) or ILSAC GF-5 (or better). You can also use 0W-20 oil in the UK as it was retrospectively approved for use in the 1NZFXE-NHW20 motor.
    Don't try and save money by buying cheap oil. Oil is the life blood of the engine.
    Also change the oil filter every oil change. I recommend the OEM filter (part nbr 90915-10003 (PNC 15601)).
  16. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    Which one do you use the Gallon Jug (3.78 Liter) or multiple Quart Bottle (946 mL each) ?
    Because the owner's manual says to refill 4.4 qt. (4.2 L) with filter or 4.1 qt. (3.9 L) without filter.
  17. dolj
    dolj Senior Member
    8,652
    4,404
    I'm not sure why it matters to you. Usually, oil is cheaper per litre, so it would be preferable to get the 4 L (or gallon (US) jug).
    FYI, you are posting in a Gen 2 forum, and the oil refill quantities for the Gen 2 are different from those for the Gen 3.
    kamrul and Mendel Leisk like this.
  18. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I've used only synthetic oils in all my vehicles for the last 30 years. I've had virtually no engine wear at all since. Vehicles start at any temperature, and I only need an oil change twice a year. I'd use a 0W20 in the winter.
    I can't imagine why anyone would use a non-synthetic.
