Tags:
  1. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    OK well I changed the oil last winter in really cold weather on Prius and a Caravan and alls I had was about 6 qts oil, and it had to be done fast within the amount of oil I had. And I believe its OK to skip a filter changes once.
    This winter is much warmer so I just changed both filters and oil both cars (since you guys made me feel so guilty).
  2. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    I've found this Japanese synthetic oil called Totachi, many mechanics advised me to use it. I've used 5W20 as it,s not so cold hear in Jordan. [​IMG]
  3. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    ...the ZFM is molybdenum sulfide additive which I would be a little concerned about but its probably OK. It appears this brand is not used in USA/EU so it does not have the ACEA A1/B1 rating that would be helpful. I'd rather see you use Toyota or major brand but this is presumably OK. I saw no consumer reviews on the Internet so its not a brand most of us are familiar with.
    #23 wjtracy, Dec 30, 2015
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Damn, that looks good enough to drink.
  5. Andyprius1
    2,327
    859
    Cool CA
    That's much more equitable, you are redeemed. Just for that you are going to get one of those pretty cans of oil just shown above this post. "OILE" " HAIL TO THE DEFENDER OF THE LUBE"
