Engine on initially with EV mode, never get 199mpg
Discussion in 'Prime Main Forum (2017-2022)' started by Roy2001, Feb 14, 2018.
  1. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    I just bought a Prime Premium 10 days ago and really like it, it just sips the gas.
    I have it charged during the weekend and test with EV mode (not EV Auto) but found that engine is always on during the morning. So MPG is miserable at beginning for about half mile, and then it turns the engine of so I can achieve like 120MPG after a 5 miles trip.
    In on occasion, even after I stopped the car after the trip, the engine was still on, but panel is not showing that engine was on, either it show the battery was being charged. It lasted for more than 10 seconds after I fully stopped in garage and pressed parking key.
    I am in Northern California, during morning temperate is around 45F, battery is full with 26 mils EV range. I live up the hill so it is down hill when I leave and EV range was almost same after I drive to school and it only drain the battery when I drive back. So I don't see any reason why engine would be on give the temperature and down hill and I press the gas pedal very gently. If it is to warm up the engine, then why it would turn it on after I reach the home?
    Can I completely shut off the Engine when I drive in EV mode? That's all the purpose I bought a Prime.
    Update: no AC, no heated seats, nothing was turned on when I leave the home except driving in EV mode.
    Sorry I searched "engine on" and now searched ICE and found 2 related threads.
    ICE comes on anyway | PriusChat
    Cold weather cruise control and unexpected engine ON | PriusChat
    49,509
    after how many seconds/minutes does the engine fire up?
  3. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    You sure you’re in EV and not HV?
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    This:
    causes this:
    Because the battery is full when you leave and the car immediately has a long regen (charge) opportunity while going downhill but there is nowhere for that excess charge to go since the battery is full. So, the computers start and use the engine to burn off that excess charge.
    There are workarounds for this but I'm not familiar enough with the choices available to the Prime to give you suggestions. For example, the Chevy Bolt EV has a setting in the charge menu to purposely not fully charge the battery so there will be an available buffer in the morning to absorb the regen charge while going downhill.
    Travis64 likes this.
  5. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    Do you have the defroster on? I think that starts the engine.
  6. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    just to check, are you driving with shift lever in B mode?
    I have inadvertently left in B mode after using to slow down on a long grade to a stop sign coming off a freeway, and this behavior sounds a lot like what happens when I did that.
  7. ct89
    ct89 Active Member
    323
    266
    New England
    What distance or type of hill are we talking about? I usually head downhill for a mile or so before hitting flat land and the car stays in EV mode the entire time. I'll even see more EV range than when I started due to the bit of regen I get going down the hill....
    I ask because at some point a long enough hill might exceed what the car is willing to pump into the battery but for shorter hills do not seem to be a trigger.
  8. bwilson4web
    15,524
    Posted at 30-35 mph in 40F weather, I had one engine on even on the ascent and two on the descent. Stopping the car and power-cycle turns off the engine and reverts to EV mode.
  9. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Yes, the ice runs for a few minutes in the first fifteen minutes of use, nothing you can do, think of it as saving your electric range a bit.
    I live at 1480' and everwhere I go is at 500' so yes my ice comes on even when going downhill, I prefer to use the ice when going up steep hills to save the traction battery for flats, going into winter I was averaging 97.3 but now I've slipped into the 80's, the ice won't turn off below 18 degrees, another unfortunate prius fact.
  10. ct89
    ct89 Active Member
    323
    266
    New England
    Interesting...Is altitude a factor in a Prime turning on the ICE?
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    If you don't charge to full at home, but only to perhaps 80% or so, you might be able to keep it off.
    I've had the engine stay off for an entire trip down to 12°F.
    No, change in altitude is. His problem is trying to regenerate into an already-full battery.
  12. muleman
    muleman Junior Member
    56
    48
    rochester ny
    neutral and roll down the hill.
  13. MikeDee
    1,550
    590
    Why would the engine come on if the battery is full? I would think of it did, it would be like B mode where there's engine braking but not fuel is being burned.
  14. Lee Jay
    5,850
    4,024
    Fuel is being burned during engine braking. Plus, if the engine hasn't been brought up to temperature previously, it has to burn fuel to run through the warmup process.
    Prodigyplace likes this.
  15. Roy2001
    371
    158
    Sacramento, CA
    About one mile down hill, and I can see battery range increased by 0.8 miles.
  16. ct89
    ct89 Active Member
    323
    266
    New England
    I see a similar thing...Leave my house, drive downhill about a mile...I usually burn a couple of tenths of a mile of EV range before I get to the steeper part of the hill, then recover and end-up about a half a mile of EV range over where I started.
    I have not noticed the ICE starting...I keep the trip gauge set to "since last start" so if the ICE did come on and warm-up I would not be at 199.9 MPG at the bottom of the hill...
    Maybe your hill is just steeper enough or just longer enough??? Clearly the battery has some extra room after a full charge because I can absorb more energy and see a larger EV range value...But I have no idea how much.
  17. bisco
    49,509
    have you tried it without a full charge?
  18. MikeDee
    1,550
    590
    #18 MikeDee, Feb 17, 2018
  19. Lee Jay
    5,850
    4,024
    Knowledge of how engines work, observation of non-infinite MPG during engine braking on many cars, and the fact that warmup has to happen if it hasn't happened already.
  20. MikeDee
    1,550
    590
    Pure B mode with the foot off the gas cuts off the fuel flow, from what I've found in internet searches. Makes perfectly logical sense to me as why waste fuel during engine braking when it isn't needed? Yeah, probably triggers a warm up cycle though.
    Fuel is cut off on gassers too during deceleration GM says deceleration fuel cutoff in Cruze increases fuel economy by up to 2% - Green Car Congress
    #20 MikeDee, Feb 17, 2018
