engine overheating, dealership is stumped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bullcub, May 14, 2013.
  1. Bullcub
    Bullcub New Member
    My 2008 prius overheated a week ago, my scangage said the engine coolant was 247, coolant had come out the overflow tube on the reserve tank behind the radiator. I rented a tow dolly and towed it 170 miles to a Toyota dealer. They replaced the thermostat, I towed it home. The next day I drove it 70 miles on the freeway, shut it off at a rest stop, started back on the freeway and it overheated within two miles. Had it towed to dealership again. They found frayed wires leading to the hot coolant storage tank, told me that was the problem. Started for home, once again I stopped after about 65miles of highway travel, shut it off, hit the road again and two miles later its overheating again. Towed to dealership again this afternoon. They say their most senior hybrid mechanic is the one that's been working on it all along and they'll keep it until they figure out the problem. All I've read online deals with the electric water pump problem for the HV system. This is the engine cooling system and I can't believe their mechanic doesn't know how to purge air from the system. They pressure check the system every time. Any thoughts would be appreciated, thanks
    JMD likes this.
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Hopefully they check the radiator electric cooling fan operation as well as making sure the AC condenser airflow is not obstructed with insects and leaves.
    Does your scangauge allow you to monitor the radiator fans?
    koolingit and JMD like this.
  3. Bullcub
    Bullcub New Member
    I don't think so, its a scangauge II I bought from this site years ago.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I think a trip to a different dealer is in order......
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Although not common on the Prius engine after checking the drive belt to the coolant pump, the pump itself, and the outside of the radiator for blockage, and of course the thermostat. The next thing would be a suspect head gasket.
    John (Britprius)
  6. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    Im betting on the fans, the fans are used the most when the engine is hot and there is insufficient airflow. I.E extended idling or low speed driving.
    I suspect the radiator is sufficiently cooled durring your highway speeds but needs the fans once you stop or are operating at low speeds which is no longer moves enough air through the radiator.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Where is your location and what's the temperature currently like there?
    Also, have they checked the oil and the coolant to make sure there's no sign of a blown head gasket?
    Wow John, you posted that while I was typing. :)
  8. Britprius
    5,194
    1,922
    You've got to be quick these days.:)
    John (Britprius)
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    From the OP's description of the event it didn't sound too much like low speed driving to me. Just one rest stop on the freeway and the Prius shouldn't have been idling at all. It's hard to know how demanding the operation was on the cooling system without knowing the ambient temperature or the terrain the OP was operating in.
  10. Britprius
    5,194
    1,922
    It is not unknown for the fans to be in the wrong positions if front end damage work has been carried out. This can be checked by turning on the AC and standing in front of the car. If air is blowing out of the front grill the fans have been swapped.
    John (Britprius)
  11. Patrick Wong
    18,210
    6,517
    Too bad their senior tech doesn't understand that the coolant heat recovery storage tank wiring will have nothing to do with an engine overheating issue.
    I would agree with the posts that the most likely cause would either be reversed cooling fans (the fans should be sucking air from the radiator) or substantial air in the coolant loop. You can check both of these items:
    1. Turn on the air conditioning, MAX COLD temp setting. Both radiator fans should be running. Observe which way air is flowing, to verify the fans are spinning in the correct direction.
    2. Turn on the heat, MAX HEAT temp setting, maximum cabin ventilation fan speed. Do you have good heat coming out? Do you hear any gurgling air bubbles? If your answers are yes and no then hopefully you don't have air in the coolant loop.
  12. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I can attest to that. My x-wife had a front end collision with my 07. After the repair, I had the same symptoms. The fans were reversed...
  13. Bullcub
    Bullcub New Member
    Patrick when it overheated the first time I turn the heater on high to help cool the engine down but it wouldn't blow hot, just outside air temp. But anyways the plot has now thickened with the latest call from the shop. It seems they have discovered hydrocarbons in the radiator 142 ppm, which they say is a sign of a blown head gasket and exhaust leaking into the cooling system. They also report smelling exhaust and seeing tiny bubbles when the radiator cap is removed. I am Curious as to how it would pass two pressure tests.
    John that's exactly what they suspect now, a blown head gasket. They measured 142ppm hydrocarbons in the radiator, can smell exhaust and see tiny bubbles with the cap off. But I don't understand how it could pass two pressure tests.
  14. Patrick Wong
    18,210
    6,517
    Odometer reading?
    Are you aware of any issues besides the engine overheating episode which would have stressed the engine and damaged the cylinder head gasket?
    I suggest that you request a cylinder leakdown test be performed to verify a problem exists with the cylinder head gasket.
    The radiator is typically operating at ~15 psi. An engine cylinder will experience much higher operating pressure. Typically the pressure is over 100 psi just at 300 RPM cranking speed (for a normal gas engine) so it will be much higher when the engine is revving up.
    uart likes this.
  15. Bullcub
    Bullcub New Member
    the latest news from dealer is blown head gasket, exhaust leaking into coolant.
    85,000 miles and no other episodes
  16. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Assuming they are sniffing 142 ppm of HC at the radiator neck, there is an internal engine concern, most likely a head gasket or cracked/warped head.
  17. Britprius
    5,194
    1,922
    I am glad the the problem has now hopefully been resolved, but feel the dealer let you down by not carrying out a simple test checking for exhaust gasses in the rad.
    Hopefully it is just the head gasket and not a cracked head "not trying to scare you but it is a possibility" however unlikely.
    John (Britprius)
  18. N_gineer
    N_gineer New Member
    New York
    I have a 2011 prius (I guess gen III) at like 135k I started getting a "rattling noise" from the engine.. I got all oil changes etc done on time, I did a perfect maintenance. They checked everything, and finally found out that head gaskets are damaged.. No check light, no overheat warnings. And the engine kept on losing coolant slightly (it was going into the engine) - the dealer couldn't explain why this happened.. I ended up spending $3500 to get head gaskets, coolant circulation pump and the heat sensor replaced.. the service never took a small responsibility on behalf of toyota.. They tried to sell me a new prius...
  19. bisco
    52,761
    welcome!
    uncommon, but it happens. sorry you didn't connect with us sooner, a salvage engine is typically a better route.
    all the best!(y)
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Another engine destroyed by dealer maintenance.
