Engine Ping - mechanic recommended SeaFoam
Discussion in 'Newbie Forum' started by Bgustafson, Jun 7, 2017.
  1. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That probably is NOT as simple as you seem to think.
    And it does not change the fact that mixing solvents with your oil is NOT A GOOD THING TO DO.
    Marketing claims (lies) not withstanding.
    RCO likes this.
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    if it removes carbon it has to go somewhere and what damage are the chunks causing as they rattle inside..
  3. Sam Spade
    2,036
    1,024
    2017 Prius c
    None. The hope is that most of it burns off.
    And carbon that accumulates inside an engine is really not hard, compared to the metal the engine is made of.
    Paranormal Rob likes this.
  4. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    If carbon damaged our engines that way, we wouldn't drive long.
    Youtube and you'll see some examples.
    Raytheeagle likes this.
  5. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    And you can prove BG Products don't work or are harmful to use? If so, share that info.
  6. Sam Spade
    2,036
    1,024
    2017 Prius c
    I don't even know what BG products ARE.
    And I didn't say that none of them don't work or are harmful.
    What I did say is that dumping solvents into your oil is a BAD thing to do.......no matter what brand name the can has on it.
  7. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    "sold exclusively through a worldwide network of distributors"........is a dead give away that one of the company's biggest skills is:
    DECEPTIVE MARKETING.
    I am sorry that you are wasting your money every month but I have ZERO faith in any of this snake oil.
    You NEED nothing extra for your car to run for maybe 200,000 miles.
    And some things, like diluting your oil with solvents, actually tends to make it wear faster.
    Tbkilb01 likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I began using EPR and 44K after I began to notice oil consumption on our 2010 Prius II at around 120 k miles. After the EPR flush and in the next batch of oil, I began using the MOA and then Extended Life MOA.
    Here's what the rep has been saying that I am working with:
    [POLL] Excessive Oil Usage
    I've been able to reduce oil consumption from a quart every 4500 miles to less than a quart every 10 k mile oil change:).
    Just another data point(y).
  10. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Thats always possible.
    One thing I keep going back to is reading many stories of taxis that go 200,000-400,000+ miles with just regular maintenance. I've even seen engine teardowns with little damage after 400,000 miles.
    I wish there was a way (or is there?) to know approximately how many miles the engines actually have. One advantage getting it at only 34k miles, I'll know how the maintenance has been done almost from the beginning.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Those are more than likely the Gen2s that have the VVT as opposed to the egr system on the Gen3s. With this, we have been finding the intake manifold and egr systems clogged with carbon. Here is a thread of an engine tear down at 297 k miles:
    Blown Head gasket rebuild....@297k
    Some light weekend reading(y).
  12. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    So - I've since put in two cans of SeaFoam on two separate tanks of gas. I waited until each tank was down to 1/4. I have seen an improvement with the pinging. It happens less often and when it does happen, it's much quieter. However... it (is) still present at times, so I can't say it's cured.
    #32 Bgustafson, Jun 21, 2017
  13. Mendel Leisk
    42,347
    Does Seafoam gas additive raise octane? (n) Higher octane gas will reduce ping.
  14. Bgustafson
    259
    222
    Chicago
    I was wondering that as well. That may explain why the ping got worse after I filled the tank again. I used Shell gas to see if it would make a difference, and it definitely has not been as severe, but I still hear at least once a day. Today I filled up with regular unleaded from the grocery store...nothing special. I'll see how it preforms and then maybe try premium next time.
    Being a Prius driver, it's hard for me to justify putting gas in my tank that costs .75 more!
  15. Mendel Leisk
    42,347
    Well for one tank, try raising the octane, that'll tell you where you stand. Maybe you can even settle on mixing half a tank of regular, and half of mid-octane? A filling hassle though.
    I'm pretty sure the one thing that can be causing this would be carbon build-up, reducing volume (raising compression ration) and creating "glow plugs" to pre-ignite.
  16. Bgustafson
    259
    222
    Chicago
    So here's where I stand:
    - 2 bottles of SeaFoam have been run through the tank on two separate tanks of gas. Ping improved greatly, but did not disappear completely.
    - After SeaFoam, I tried a regular tank of unleaded gasoline. More ping heard, but not as severe. Engine ran lousy imo. Kinda rough.
    - I filled up my tank with mid grade this time. It sounds about the same. Ping is MOSTLY gone, but still persists on occasions. Engine has more power, which is to be expected.
    So I'm not sure what to think. Going from Unleaded to Mid grade didn't seem to do a whole lot. I feel a difference in performance and maybe SLIGHT ping improvement, but not gone. Do I try a third can of SeaFoam?
  17. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Have something like a BG fuel service done, the complete one. There are similar services, they aren't too expensive.
  18. Mendel Leisk
    42,347
    Try a tank of the highest octane?
    scona likes this.
  19. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    A full fuel system service will go beyond whst higher octane. If that doesn't fix it, something else is up.
  20. Mendel Leisk
    42,347
    I just figure start with the low hanging fruit: a tank of highest octane gas is maybe $5 more than regular? And if it does completely dispel the ping you have a strong clue that there's excess carbon, raising compression and providing alternate ignition sources. And then go to the arsenal, yeah: but it's a cheap first step.
    RCO likes this.
