Engine Ping - mechanic recommended SeaFoam
Discussion in 'Newbie Forum' started by Bgustafson, Jun 7, 2017.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Is it safe to drive until I get new plugs? Or should I hold off? I'll purchase the brand Toyota suggests.
    RCO likes this.
  2. Mendel Leisk
    42,347
    Did you check the gaps? Hard to tell if the centre posts are eroded or coated. It does like the gaps are a bit big. This is the spec from 2007 Owner's Manual (closest year I happened to have):
    RCO likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Should be ok IMHO, but stick with the premium gas to avoid the ping to your get it done. (y):)
    Edit, over here in UK we call it pinking. Something to do with the sound it makes rather than the color (colour) ok?
    #83 RCO, Jul 28, 2017
    Raytheeagle likes this.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    One should NOT try to alter the gap on a platinum or iridium spark plug.
    They come gaped from the factory.
    Paranormal Rob and RCO like this.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Did not know that. Thanks, the old ways are not always the right ways today. (y)
    Paranormal Rob likes this.
  6. Bgustafson
    259
    222
    Chicago
    The ones I have installed were Denso, so I'm replacing with Denso. Will do that later today.
    RCO and Paranormal Rob like this.
  7. Bgustafson
    259
    222
    Chicago
    Hi everyone, the good news is the plugs arrived, and I replaced them very easily.
    The bad news is the pinging has reduced, but is not entirely gone. I still often hear it subtly - especially when I'm going up hills and the engine is working harder.
    Thoughts?
  8. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
  9. Bgustafson
    259
    222
    Chicago
    Interesting, how long does this process normally take? I've had them installed for 4 days.
  10. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    I think it depends on mileage. Someone else may know more about that part. Make sure its Top Tier gas as well.
    Mine didn't need plugs but when I had Toyota do the fuel system cleaning on mine last week and I already had E0 BP gas in it, my mpg went up 3-4 mpg.
  11. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    I am using BP E0 89 octane....cheaper than 87 at other BPs. Go figure. Like, 40 cents per gallon cheaper.
  12. Sam Spade
    2,036
    1,024
    2017 Prius c
    And you need to tell us the REST of the story.
    Like what octane gas are you using with the new plugs.
    I think you need to visit a DIFFERENT mechanic because this noise you are hearing might NOT be simple detonation ping.
    A "decarbonizing" procedure probably won't hurt anything if done right.......but I suspect that it won't help either.
    Sometimes small noises appear in older engines and the cause isn't always easy to identify.
    RCO likes this.
  13. Bgustafson
    259
    222
    Chicago
    I'm back to using unleaded, 87 octane, Top Tier. Most of my stations use 10% ethanol in their mixes, including Shell.
  14. Sam Spade
    2,036
    1,024
    2017 Prius c
    OK, so you have a decision to make:
    Either do a "de-carbon" in an attempt to fix the problem.....OR......start using a higher octane fuel.....OR.....start shopping for a new car.
    Or maybe just live with it.
    Top Tier and ethanol have no bearing on your present problem.
  15. Bgustafson
    259
    222
    Chicago
    I'm OK living with it, as long as I understand what the issue is and if it's causing damage.
    RCO likes this.
  16. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    So a few decades ago, BMW and Mercedes realized there could be SIGNIFICANT differences in "octane" between two fuels with the same Pup Octane number. It is more than possible that due to age, wear and a multitude of other conditions that cannot be accurately measured, the Pump Octane you have is simply sub-optimal for your engine. Switching brands in the US can alleviate this in some cases.
    Why? Pump Octane is nothing more than the AVERAGE of Motor Octane and Research Octane - have you ever noticed the 87 = (R+M)/2 printed on the pumps? yup, that's what it means, the AVERAGE of the two. Maybe your common brand (or mix) has a relatively high Research but a low Motor octane -> The AVERAGE could still be 87.
    For motor vehicles, not race cars etc, Motor Octane is often, but not always the more important. Guess what, ethanol is highest in Research octane and it degrades over time and moisture.
    USDM cars have knock sensors that monitor for "pinking" and adjust timing accordingly, within certain limits. Given your ECU cannot adjust enough, my guess is that the AMM/MAF is dirty causing more air to enter than the engine thinks. Combine that with a old and tired WBO2 and you have "pinking".
    I don't think you are in any real danger of hurting the engine. Ford tests ALL their engines for nearly 40Hr of continuous HARD KNOCKING and will not approve the design unless it can pass the test, I doubt Toyota are slackers in this measure.
  17. Sam Spade
    2,036
    1,024
    2017 Prius c
    BUT......the truth IS that you don't really know what it is until you fix it.
    All the evidence points to a pre-ignition ping because the "premium" gas seems to fix it.
    But there is a tiny little chance that the noise is something else.
    At the very least, if you can get rid of it by using a higher octane gas you SHOULD DO THAT.
    Over a long period of time, whatever is causing the noise might do some damage too.
    RCO likes this.
  18. Bgustafson
    259
    222
    Chicago
    I will try to get a second opinion from another mechanic.
    RCO likes this.
  19. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  20. Bgustafson
    259
    222
    Chicago
    Yeah I have to take it in to get the combination meter fixed anyway, so I'll ask them. I try to avoid dealers as much as possible because they usually attempt to gouge you.
    RCO and Prodigyplace like this.
