Engine Ping - mechanic recommended SeaFoam
Discussion in 'Newbie Forum' started by Bgustafson, Jun 7, 2017.
  1. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
    I haven't had that issue so far. I do know after I had the fuel service done a couple weeks ago my mpg is going up again and I only had 40k on it and not old plugs like yours. So it probably help.
  2. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Bgustafson likes this.
  3. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    I still suggest you have it done, especially with those plugs being that bad. There's probably lots of carbon build up and if the mechanic suggested Seafoam, a fuel system treatment will do a better job and quicker. And I think that will take care of the pinging.
    If you Google carbon and pinging you'll see lots of related info, as well as other things.
    RCO likes this.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Speaking of SeaFoam, I was in Autozone yesterday and noticed that the price has gone up to almost $11 a can.
    Pretty expensive for a mixture of white gas, alcohol and kero.
    And yet people still buy it.
    Maybe this is some kind of marketing social experiment to see if there is a limit to what people will pay for snake oil.
    RCO likes this.
  5. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  6. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Snake oil that removes carbon from pistons. Proof is in the videos he does on each piston before/after use.
    So once again....you're wrong.
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    The "ignore" user feature of Prius Chat can be your friend;).
    I use BG Products EPR yesterday and added some MOA. I have seen the benefits and so have others. I will continue to use it as part of a preventative maintenance routine every oil change.
    Remember: ignore can be bliss(y).
  8. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    I was using the phone app and couldn't find it. I just logged in thru the site and there it was.
    All is peaceful again.
    Actually since the Seafoam here was on sale buy one get one, I bought 6 and was going to use those at oil chsnges. I know when Toyota did the fuel system service (similar to BG, except they unhook fuel line from gas tank instead of pouring it in) my mpg has gone up 4mpg or so.
    I also went from E0 87 BP to E0 89 BP ( 44 cents cheaper than 87). Last fillup was 47.6 mpg. I want to see 50. Driving Uber/Lyft is a challenge as my routes are never the same. I think when it gets cooler I can get 50.
  9. Sam Spade
    2,036
    1,024
    2017 Prius c
    You have "proved" something that I didn't say.
    What I said was: A little bit of carbon on the pistons or a little bit of fuel stain inside the manifold or a bit of sludge in the sump DOES NOT CAUSE A PROBLEM AND DOES NOT NEED TO BE "FIXED".
    All of that smoke coming out is the SeaFoam itself burning but not igniting fully.
    It is gullible people like you that enables them to charge $11 a can.......for a product that probably costs them about $2 to produce.
    Ignorance is bliss. I am glad that you are happy.
    RCO likes this.
  10. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Then again, the fuel system cleaner they did is recommended every 30,000 miles (I had 40k but bought it with 36k) so I may bypass Seafoam altogether. Using the BP E0 89 should really help out.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    50 mpg in a v wagon would be something to see(y). E0 gives you the best shot. How many miles on your v?
    One device that can help improve mpg is something I beta tested for @Pedal Logic that filters the electronic signal from the accelerator pedal. It gave me a 4 mpg bump. Might be worth PMing Marc if you want to see 50 mpg.
    He might even be able to tell you how it performs on a v, given he has one in his Prii stable(y).
    Paranormal Rob likes this.
  12. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Just 41k now. 2013 1 owner from Atlanta area. Got it thru Carmax, awesome car. Probably the first I bought that I didn't want to change speakers, wheels or anything. If that stereo doesn't have a sub I would be surprised because the bass is that good.
    How exactly does Pedal Logic work?
  13. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Similar to this?
    And the way they explain unintentional pedal movement happens to me all the time because its bumpy and uneven everywhere here.
  14. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Here's some light Sunday reading for you on the subject:
    (5) beta testers sought for new technology
    Good info and Marc is a wealth of knowledge on the subject(y).
  15. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Beta testing completed ;).
    But production units are available(y).
  17. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
  19. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
    Awesome. I only saw for fleet cars and trucks and transit. Are we fleet car or something different?
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I know Marc was in the commercial end when he brought the beta testing opportunity to Prius Chat (has had logged millions of miles on buses and fleet vehicles). I was chatting with him yesterday at our Bay Area meet up with his Business partner Attila and they were doing a "Kick Starter" campaign. I believe Marc said he is staying out of the private owner Arena, but not sure. You might be able to convince him otherwise;).
    He gave me a new PCB at the meetup, and we'll probably get together and I'll give him the pattern for the RX450h so he can work on development there.
    PM Marc and let him know where you're at and you might be able to work something out(y).
