Engine Problems: Any thoughts??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dave C, Dec 31, 2005.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Dave C,
    When you take it in to the dealership, make sure to tell them that the reason you know about the oil overfill and the oil pooled in the intake is that a Prius Tech helped diagnose it online. I say this only in case they might try to say that you know about it simply because it's your fault. Long shot? Perhaps. All the same, if you have to, offer to show them this thread. I did exactly that when I was having problems and showed the Prius tech a thread in which the resident experts explained things in complete detail better than I ever could. After reading a few of the posts, the dealer Prius tech was like, "huh, okay that makes sense."
    Best of luck!
  2. Dave C
    Dave C New Member
    17
    Owings Mills, MD
    Tony,
    Good call: I plan to do just that. I want to be as prepared as I can to make sure this gets resolved. Either way, I pay them to handle my maintenance -- Unless there is a more insidious problem at work here, there shouldn't be oil in the throttle body either way. But I do plan to take a copy of these threads. I am really stoked that there is such an informed body of Prius frea...I mean fellow enthusiasts that could point me in the right direction!!
    Regards,
    Dave
  3. Dave C
    Dave C New Member
    17
    Owings Mills, MD
    Frank and galaxee,
    My grandpa was a genius with conventional combustion engines in his day and warned me against overfilling an engine with oil. He said that the oil could froth in the heads. It would seem logical that there would be a substantial increase in the oil pressure as well; the oil expands under a heat load, that pressure has got to go someplace. I just hope if galaxee's diagnosis is correct, and it seems to be on the shortlist of possible explanations (given the evidence), that damage hasn't been done. I put 1K miles on it (after the service) in this condition. Only now did it fail, so that makes me a bit worried. Still, we need to entertain other possibilities (until proven incorrect), so will also check out the fuel filter/bad gas scenario to be sure. But there's oil in the intake, that's a certainty. I may even photograph it tomorrow. This is a good learning experience, albeit an inconvenient one (hopefully not expensive). Thanks for the continued support and ideas.
    Regards,
    Dave
  4. rick57
    rick57 Member
    572
    Circleville, Ohio
    I agree that a very over fill of the crankcase might cause a check engine light. But there are other items on the 1G that could turn it on. I would still get the level corrected but also have them pull the trouble codes and not just use the Diagnostic Tester to clear them all.
    If it is a No Start code there is a TSB that has detailed descriptions of the various codes/sub codes and what would cause them ( TSB, EG011-03 ). Besides oil overfill/quality, it could also be fuel pump,ECU,Circuit Opening Relay ( for the pump circuit ).
    Another cause I have seen is the Accelerator Position Switch,which is part of the pedal assembly.
    So I guess at this pont you need to have the oil level corrected and have them pull the codes. Have them note the codes on the Repair order so we have more to go on. Without them we are just making our most Educated Guess, :lol: . And I would say there are some educated members here, ;) .
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    i also asked DH to explain the overfill going into the intake. he said something about the compression ratio, the pcv valve, and the intake. then i got a phone call from a friend. when i got off the phone, he was asleep so i guess that's the end of that... :lol:
    some input from rick too, always a good thing. more good minds cover more ground and uncover more possibilities to look at.
    well anyway, however the oil got in there, make sure they clean that out and let's hope that was the problem. let us know how they handle the issue.
  6. TonyPSchaefer
    14,816
    2,501
    66
    Sorry, Dave, to jump so far off topic, but I've got to settle this. Galaxee, I can't take it anymore. I know your married but can't seem to figure out what DH stands for.
    BF = boyfiend
    GF = girlfriend
    SO = significant other
    DH = designated hitter?
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    domestic hinderance :rolleyes:
  8. galaxee
    9,810
    471
    MD
    :lol: :lol: :lol: :lol: :lol: :lol:
    i do not know, common use appears to be "DH" for husband and "DW" for wife on forums. and it's shorter than typing out 'my husband' or 'my hubby' all the time. i am a lazy typer.
    let's say it stands for Doug my Husband. i can come up with a ton of other things that would fit the abbreviation, but we'll stick with that ;) and no i won't post my real name. :lol:
    [edit: Tony, you are in bears country... it could be Da Husband and Da Wife :lol:]
  9. richard schumacher
    7,682
    1,062
    United States
    Any possibility that the engine was running while they were adding oil? It may be hard to believe :) but people do sometimes fail to turn the car OFF correctly. I've known more than one tech who liked engines running while he topped off the oil, which may be a particularly bad idea in a Prius.
    Next time tell them to put in three quarts exactly, and check the level before you leave.
  10. driveprius
    driveprius New Member
    112
    Delaware
    Please let us know how this turns out. I'd say it's a little bit frightening thinking about having my Toyota Prius serviced by Toyota service. I'm still under 2,000 miles so it will be a few months before I have to make my first scheduled visit.
  11. Dave C
    Dave C New Member
    17
    Owings Mills, MD
    Richard,
    Unfortunately, I'd have no way of even knowing what they did as I never get any face-time with the mechanic. The "service manager" always acts as the go-between, likely because the mechanics have more work than they can handle. It's pure trust that they are doing what they should be and say they are. That said, as I mentioned previously, there have been subtle signs through other service experiences that they act in a big hurry and I am becoming increasingly suspicious of the quality. We've been screwed on scheduling of service & detailing, had a very greasy interior to clean up when the car was returned, and I explained the coffee incident in a previous post. Also, a couple of times we requested things to be done and they were not.
    Now, you and everyone else might ask, what the hell am I still doing taking it to this dealer?? Good question. Well, this is our only vehicle, and the dealership happens to be within a 1/2 mile of my home, so I walk to and from. So while it is convenient, the outcome of my present sitiuation will dictate future choice.
    I am going to be at the dealer tomorrow morning at 6:30am. I will meet with the shop foreman and service manager. I will be very polite and professional -- but will state my displeasure and expectations in no uncertain terms. If this meeting goes poorly (they get defensive and uncooperative) then I will dial Toyota Customer Service on my cell and we'll all have a conference call and get it sorted out.
    Yes, I will be checking the oil whenever I leave the dealer henceforth. I expect, however, that when maintenance is performed, it is done with integrity -- that is why I own a Toyota (and a Prius!).
    Dave
  12. Dave C
    Dave C New Member
    17
    Owings Mills, MD
    Driveprius,
    I wouldn't sweat having service performed by the dealer. Despite my present concerns, I wouldn't take it anywhere else. After all...what choice do you have? No one is better suited to service this vehicle than Toyota. Still, my recommendation would be to establish a relationship with your service manager and staff, up front (You would do the same if it was an investment counselor or financial planner right?)
    I have enjoyed 99% reliability up to this point (39 months of ownership). The 1% was for a warning that resulted in a warranty motherboard replacement. The car continued to operate just fine during the warning. I couldn't be happier and will not drive any other kind of car, both for ethical and environmental reasons, but also that Toyota makes a superior product -- end of story. I plan to hang on to this car for another 4-5 years. My next car will be a 2010 Prius!
    Don't worry ;),
    Dave
    p.s. I am still envious of all of the cool aftermarket products coming out for the 2006 models though!. Wish I could pimp out my ride! :lol:
  13. jeromep
    jeromep Member
    827
    Eastern Washington State
    You are going to want to run the lowest octane available in your area. Unless you live at a high elevation, like Denver, that should be 87.
  14. Dave C
    Dave C New Member
    17
    Owings Mills, MD
    Ok, here is the outcome to my tale. I'm sorry I couldn't post sooner but I couldn't get onto the Forum at all the past couple of days.
    The tip-o'-the-hat goes to Galaxee for the pre-diagnosis but my hat's off (were I wearing one), to ALL who pitched in -- your help is very much appreciated!!.Too much oil was added during the 45K service; about 2 cups worth. Indeed the Prius is very sensitive to this it seems. Maybe my running 92 octane for our roadtrip contributed, although we had no issues during the trip and averaged 49.2mpg on the return.
    The dealer was extremely gracious about the oversight. They took care of it immediately and without question and were very helpful. The oil level was lowered and the throttle body cleaned. Kudos to them as well as they also asked about the octane. I was told not to run the hot stuff (as others here also mentioned). It's interesting because I read the owners manual and it ONLY states not to run anything less than 87. It doesn't specifically state to run just 87. But I will from now on, and that's an extra cost savings.
    Anyway, the car is running smoothly again. We've refilled with 87.
    Thanks again to all for the assistance and suggestions; it made this a lot easier and I learned some interesting things.
    Regards,
    Dave
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Thanks Dave, for letting us know how it turned out. I'm happy the dealer did the right thing and that your car is OK now.
    I am curious why an octain of greater than that recommended might be bad? As previously mentioned the owners manual doesn't warn against it. My understanding is that higher octain fuels can be compressed more before they detonate or explode but that there is no other real difference in the way they burn normally. So that would imply that you would be wasting your money by buying higher octain fuels than required but that it would do no damage. There is one possibility, Toyota may use a system that leans out the mixture until preignition occurs then sets it a very small ammount richer than that. Mazda and Mitsubishi used such a system at one time and they warned against using higher octain than recommended in the owners manual because the mixture would end up to lean. I have no idea if the Prius has such a system I am only speculating.
    At any rate my question is only academic, I plan to use only 87 octain fuel anyway.
