Engine rattling under heavy stress
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KJP, Apr 25, 2015.
  1. Patrick Wong
    18,210
    6,517
    Yes, you could change the PCV valve but that has no impact on the pinging.
    The engine oil probably is being burnt if there are no leaks. It could be leaking into the combustion chambers via the valve stems, or the piston rings.
  2. niphonk98
    niphonk98 Junior Member
    San Francisco
    Hey Patrick
    Do you know about restrict
    Oil flow? My friend told me this noise from metal hit
    Metal without oil. It's mean oil didn't come up enough to protect value and camshaft. They said need to overhaul value job.
    iPhone ?
  3. Patrick Wong
    18,210
    6,517
    Since you know that the engine is consuming oil at a rapid rate, rather than overhaul the cylinder head, I would suggest that you just buy a used engine and have it installed. The cylinder head may not be the only problem - if the pistons are worn or the crankshaft bearings are bad, your engine will continue to have problems.
  4. geekwithoutacause
    geekwithoutacause Junior Member
    63
    Phoenix az
    You can actually use lower octaner at Higher altitudes. It has more to do with the engine having to work harder on inclines.
    The knocking (which is what it sounds like) might be caused by bad spark plugs (when last replaced?), bad ignition coils (pull them and check for cracks in them, easy to do ) Coil boots bad, water inside the coil boots. Much much less likely is timing chain. They are not supposed to wear out.
  5. dat2109
    dat2109 Junior Member
    26
    17
    Carolinas
    I've heard the pinging under load in these engines too, its not that bad in the few I've listened to, but there.
    How much oil are the other pinging cars burning?
    I've also noticed that the amount of pinging a driver reports has more to do with their preferred radio volume level or hearing ability rather than having a lemon prius compared to all the rest!!
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I have the same experience as the OP. Exactly the same! I wonder what he ended up doing. Just want my Prius to run smooth on regular.. What a dream ☺
  7. KJP
    KJP Junior Member
    Rochester, ny
    Sorry for the late response. I am simply using 93 octane. I decided the $200+ for the knock sensor wasn't worth it. It will still knock every now and again, but much less than it had.
    Aaron Vitolins likes this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    A pinging engine is sometimes caused by the engine being overheated or poorly maintained. Poorly meaning coolant never changed or low and poor quality oil or clogged rad.I would get a Xgauge and monitor the engine temps when it is pinging. In this car you will never know if the engine is overheating until its to late as there is no temp gauge.
    If its pinging so loud that spark retard does not help it then its out of the range of the sensor or the retard is engaged and you still have pinging which is very bad as eventually engine damage will ensue.. You will know if its retarded as acceleration is poor like the battery is low.
    If pinging bad try replacing the sensor. Its pretty easy its right behind the intake manifold up against cylinder wall #2
  9. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Very good info above! Thank you for posting that knowledge. Also, I'd like to add. You can buy a new senor for $67 on partsgeek.com you might be able to find cheaper, not sure! Thought I'd let ya know
    edthefox5 likes this.
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Thanks. Lots of reports about G2's pinging but no resolution. I have never heard pinging in my 07 no matter what gas I use.
    Been using gas that has no ethanol for quite a long time. Its 87 octane and about 30 cents more a gallon. Its at a new to Florida chain 7-11 type store called WaWa. I heard there big up north. But not using it to fix anything as I have never heard pinging.
