Engine rattling
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dan05979, Jul 16, 2019.
  1. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    I had a cylinder 1 & 4 misfire, I changed all 4 ignition coils, spark plugs and my engine is still rattling and i'm getting a P0010 camshaft position sensor & P0324. Now the Check hybrid system is lit up & i think it's because the batteries are low and the engine isn't strong enough to charge the hybrid battery ( i hope) Would a camshaft position sensor cause this rattling? I'm giving up soon and towing it to a mechanic.
    52,803
    have you cleaned the egr circuit?
    is it losing any coolant? burning any oil?
    spiralhelix likes this.
  3. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    Agreed with cleaning egr.
    Also, when changing ig coils, did you notice any oil on them? And oil running down from the valve cover?
    Nice ‘puter, I have the same one.
    A cam position sensor can cause issues and I believe it’s a inexpensive part, so not horrible to swap out, but I’m still leaning to egr cleaning with this project.
    -Spiral
  4. Dan05979
    Dan05979 Member
    181
    101
    I just replaced the entire egr system with a used one from a lexus ct200 low mileage. and I cleaned it before installing it. No oil on any of the spark plugs or coils just normal wearing look. No oil leaking from the valve cover just dirty oil from me getting some oil on the valve cover from adding oil.
    I just ordered a new cam sensor. Toyota wanted $145 for the part I went with one from 1AAuto.com for $40 hopefully this solves the problem.
    #4 Dan05979, Jul 16, 2019
  5. Dan05979
    Dan05979 Member
    181
    101
    no coolant leaks and yes it's burning oil which is a common problem on these 2010 engines.
    Raytheeagle and bisco like this.
  6. spiralhelix
    255
    220
    Illinois
    glad to hear the misfire wasn't caused by a valve cover gasket leak then.
    Raytheeagle likes this.
  7. Dan05979
    Dan05979 Member
    181
    101
    If i change out the fuel injectors do I need to disconnect the plug from the fuel pump? Is there a write up for the gen 3 model? I'd like to change out all 4 injectors with reman oem ones while I have the intake manifold off.
  8. bisco
    52,803
  9. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    It is not entirely necessary, but turning off the fuel pump while the engine is idling (with scan tool or by disconnecting the fuse) will reduce the amount of fuel spilled.
    Removing the injectors is fairly easy on the 1.8L.
  10. Josue Gonzalez
    Josue Gonzalez New Member
    Miami
    Did fox the problem? And what was it?
