Engine rebuilt, installed, but 1 hose missing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Groundpounder17, May 7, 2019.
  1. Groundpounder17
    104
    77
    AR
    5C7CBBC0-B74F-4DD8-B63D-8E045D3E873B.jpeg can anyone help me ID this hose. I have no idea how it went missing but it is gone. I couldn’t find it in the parts manual
  2. Mendel Leisk
    38,732
    It's from the gas tank, evap vapours, if I recall correctly. Generic vacuum line would do?
  3. Groundpounder17
    104
    77
    AR
    Thanks Mendel. I hope the Toyota parts Dept can figure out the correct part to order. It’s been about 7 weeks and I have to get my car running. I would have last night but I couldn’t find this hose. I had 2 deaths in the family and it basically put my car on hold for the past 4 weeks
  4. Mendel Leisk
    38,732
  5. Groundpounder17
    104
    77
    AR
    That’s it! Thanks. I just ordered it. It will be here in the morning
    RMB and Mendel Leisk like this.
  6. Groundpounder17
    104
    77
    AR
    Do I lube the injectors going back in? Both ends (rail side of injector and the engine side)? What’s recommended to lube with?
  7. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    I used silicone brake caliper grease.
    Raytheeagle likes this.
  8. Mendel Leisk
    38,732
    I can post some repair manual info when I get home. It says gas or spindle oil, but reading online a lot suggested Silicone greases. Everything I've seen/read suggests to take it real easy, lots of back and forth. It's easy to twist the o-ring.
    Groundpounder17 likes this.
  9. The Critic
    3,193
    2,321
    CA
    The proper OE o-rings will not twist. Maybe undersized aftermarket ones will. The main concern is tearing upon install.
  10. Mendel Leisk
    38,732
    Repair Manual info.
  11. Groundpounder17
    104
    77
    AR
    I got the part from Toyota today and after I put it all back together, filled with fluids and it’s running great
    Gshadow325, RMB, Rebound and 2 others like this.
