engine recalibration?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bluecrazymonkey, Nov 19, 2025.
  1. bluecrazymonkey
    bluecrazymonkey New Member
    26
    Earth
    I did maf sensor cleaning and throttle body cleaning like a month ago or so. I noticed that sometimes not a lot that it usually like pulls back a little then accelerates to the desire speed kinda like it was losing power.
    from what i read on reddit that butterfly flap doesnt like to be touched because it goes out of sync with what the computer thinks and there is some engine recalibration for it and the computer has to relearn?
    anyone knows if this is true and if not why has this been happening anyway im assuming maybe my maf sensor i noticed on one side of the sensor it had like slight fog spot if this could be the reason?
    toyota prius 2008
  2. PriusCamper
    PriusCamper Senior Member
    13,230
    5,352
    Pacific Northwest, USA
    Basically, when you're done cleaning the throttle body and the MAF best practice is to disconnect the 12volt battery for a few minutes which does a hard reset back to original factory settings and you will get a fresh start and the calibration efforts will start with the ones the vehicle rolled off the assembly line with.
    However if you don't disconnect the 12v after you're done, then it will still have the settings prior to cleaning and sometimes those settings will take a good amount of time driving before they're properly adjusted again.
  3. Tombukt2
    Tombukt2 Senior Member
    13,651
    2,474
    Durham NC
    12V very old and dropping below say 9v sometimes . Having to relearn at every restart.
  4. Mendel Leisk
    42,060
    I’ve noticed (albeit on gen 3) that after a 12 volt battery disconnect the car will do an unusual rev-up, the next 2~3 start-ups, maybe testing throttle response.
    PriusCamper and Tombukt2 like this.
