Engine Refuses to Turn Off at Red Lights?
Discussion in 'Gen 3 Prius Technical Discussion' started by Anthony E, Jan 5, 2017.
  1. Anthony E
    Anthony E New Member
    Orlando, FL
    Hello there! I've noticed a problem with my prius today and would like some input. Normally, at almost every red light the ICE will turn off, except in certain cases when the battery is low, I have the heater on, etc. However, today, the engine did not turn off once. Even at a red light with the battery fully charged, no heater or AC on, and the temperature was about 70 degrees, not cold. Even after 20 minutes driving on the highway, the engine would still refuse to turn off at red lights. The energy display monitor at these red lights showed no energy being produced by the engine even though it was clearly on, it was just blank as it normally is during red lights. The only way I managed to get the engine to stop at a light is when I would press the EV mode button. However, as soon as I would turn it off, even if the car was still sitting still, the engine would kick back on. Any thoughts?
    52,911
    welcome!
    how many miles on her? could be a degrading hybrid battery, or possibly a bad 12 volt.
  3. Anthony E
    Orlando, FL
    159k about. Quite a lot for a 2010
    52,911
    yes. i'm surprised you don't have any dash lights on. is it the original 12v?
  5. Anthony E
    Orlando, FL
    Nope, no dash lights on at all. I'm honestly not sure, I bought the car about 4 months ago. I believe I can find out though.
  6. Mendel Leisk
    42,381
    Accidentally shifted into B (instead of D)? I think that keeps the engine running, not sure.
    scona likes this.
  7. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    +2 on having the 12 volt battery checked. The car may be trying to charge it continually.
    Montgomery likes this.
  8. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    But even with the ICE off, the traction battery will feed 14V to the 12V battery. So why would a bad 12V battery keep the ICE running?
  9. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    I don't know specifically how the ECU reacts to a low reading on the 12V, but folks consistently report long ICE cycles (and consequent hits to mpg) as a consequence. Maybe the computer tries to direct more current to the battery to charge it. It is a simple thing to check and rule in or out, so is a reasonable place to start - particularly if one doesn't know the history of the vehicle.
    Montgomery and glutaman like this.
  10. slewinson
    slewinson Junior Member
    36
    30
    Australia
    Heater on defrost or cabin temp set way high? My wife has done it a few times.
    Simon
  11. Mendel Leisk
    42,381
    Ruled out by initial post:
    glutaman likes this.
  12. RyanM
    RyanM Member
    68
    40
    Wisconsin
    159k is not that much for a 7 year old car. About 22k per year. Just a bit above the national average.
    I have 235k on my 2010, but have seen a few over 300k (mostly used for professional driving).
    I have never used my car for professional driving. I have considered uber/lyft as a part time thing for side cash.
  13. herqulees
    herqulees Junior Member
    59
    25
    Tennessee
    Well I'm interested in hearing why a Prius would do this. Our 2014 did the same thing a week or so ago to my fiancee. Yet the day I hop in it to see what's going on it has yet to do it again. She told me the engine would stay running the whole 50mile round trip drive to/from work, most of it being stop and go traffic, for multiple days. No heater, no defrost, Eco mode on since we bought the car. 50-60F. Will check the 12v battery with a load tester if the car starts acting up again.
  14. bisco
    52,911
    not sure about menders b mode theory in post #6, worth testing. i have never used b in 12 years, so don't know.
  15. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    If so, the symptom would not repeat (unless shifted into B again!)
    fuzzy1 likes this.
