Engine removal diy advice is it possible?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drewbabich, Jun 27, 2016.
  1. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    U tube
    iPhone ?
    makbg1 likes this.
  2. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Been searching but can't find any YouTube videos
  3. Mendel Leisk
    42,265
    This has some dead links, but covers the basics, might help:
  4. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Paul Schenck and Mendel Leisk like this.
  5. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    ok so mechanic finally finished the swap. unfortunately the engine won't start and he is getting a hybrid error. he claims a scan shows there are 4 dead cells on the traction battery. I am finding it very hard to believe since I remember starting it with no errors before towing it to his shop.
    could he have messed up the hybrid connections to the new engine??
  6. makbg1
    makbg1 Junior Member
    35
    LA
    How did you remove the bolts conecting eng and tram/inverter?
  7. makbg1
    35
    LA
    Hi Paul! I'm half way removing my eng. but can't find a way to remove the 6 bolts to disassemble from transm. Mine is 2012 prius and I'm replacing engine on it.
    I would appreciate if you can help.
  8. makbg1
    35
    LA
    I did just replaced my engine on 2012 gen3 and did it with a hoist. It will be very difficult without one. Either use a hoist from top or lift the car up (watch for the windshield ) and remove the black pulley.
  9. makbg1
    35
    LA
    How to reset
    Check Hybrid System Warning Screen
    after replacing the engine?
  10. Mendel Leisk
    42,265
    Don't understand.
  11. Paul Schenck
    524
    307
    Fresno, California
    Sorry was away from the forum a while
    I removed entire engine and transmission for the swap.
    iPhone ?
  12. Paul Schenck
    524
    307
    Fresno, California
    iPhone ?
  13. Paul Schenck
    524
    307
    Fresno, California
    Here’s a link to my note book
    Prius engine swap
    iPhone ?
  14. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Vw dieselgate quick engine removal.
  15. makbg1
    35
    LA
    Gen 3 has a belt pulley on the side of the water pump that has no belt on it (gen 2 has the belt) remove that pulley in order to remove the engine easier up.
  16. makbg1
    35
    LA
    I had the same issue (check hybrid sys.) On my gen 3 and I did disconnect the 12v battery for 30min. After that it ressets and warrning goes away.
  17. makbg1
    35
    LA
    You did it from under, wow.
  18. makbg1
    35
    LA
    I did it with a cherry picker and did not even disconnect the a/c compressor.
    Paul Schenck likes this.
  19. Michael48
    Michael48 Junior Member
    26
    Seattle
    Old thread but found this video for a Prius C
  20. Allison Meggison
    Allison Meggison Junior Member
    71
    El cajon
    It does?! Where? You said on the side of the water pump there is a belt pulley but no belt? Can you elaborate please.
