Engine removal
Discussion in 'Toyota Hybrids and EVs' started by Dxta, Jun 6, 2020.
  1. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Hi guys, goodevening. Pls I'm in the process of trying to rebuild the engine of a 2006 hihy next week. I don't want to remove the engine and transaxle together, but would want to just remove the engine alone after removing all wire harnesses at the inverter/converter assembly.
    I have checked to see there are bolts holding the flex plate/flywheel to the transaxle, but can't see any, when I rotated the engine.
    Is there a way to detach the flex plate or transmission system from the engine, or there are some other things that is holding the flex plate in place?
    Thanks for your responses in advance
