Engine Replacement & Fuel Injector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JJGriffith, Aug 16, 2022.
  1. JJGriffith
    JJGriffith New Member
    Cleveland, Ohio
    When I have my engine swapped (2011, high mileage), is it necessary to replace or clean the fuel injectors? Is this an inexpensive job when the engine is being swapped or is it still as labor intensive as when the engine is not being taken out? Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    13,878
    2,521
    Durham NC
    You can buy little tools on Amazon that will activate your fuel injectors so you can squirt fuel injector cleaner through them and clean up the pattern and all of that kind of nonsense or you can pay your mechanic while he has your engine out he can just take your fuel injectors clean them and put them in I guess the used motor or you could just drop in the used motor and hope for the best with the injectors that are there it's a JDM motor the plugs may be different I can't remember the issue we didn't use the injectors that came with my JDM engine we use the ones that were in my 2013 US spec persona but the rest of the engine was a Japan domestic market set up.
    JJGriffith likes this.
