Engine replacement imminent - help?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fos4110, Jan 22, 2015.
  1. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Only if the oil is escaping past the rings. Going to good quality higher viscosity oil is less likely to cause major problems with sludge, varnish, wear, etc.
  2. Former Member 68813
    3,524
    983
    US
    Yes, but not before sludging the whole engine.
    This is by far the worst oil advise I've seen on the entire WWW.
    PriusGuy32 likes this.
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    Old farmer's trick, that has been used for generations.
