Engine Revs up abnormally
Discussion in 'Prius c Main Forum' started by Sandal, Sep 28, 2014.
  1. Sandal
    Sandal New Member
    Colombo
    My 2012 prius C engine suddenly started reving up even after taking my foot off the peddle and it doesnt go back in to EV mode at lower speeds as usual ...it is something wrong with the senses ??
    Do i need to my car to the dealership ?...is there a remedy ????
  2. james cook
    james cook Member
    145
    36
    Louisiana
    2025 Prius
    Is it cold? Is the battery letter closer to zero? Cold starts?
    minkus likes this.
    52,804
    this complaint seems to be coming more common.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Check the vent in the back seat. Usually this vent being clogged is the culprit.
  5. xpolicy
    xpolicy New Member
    This is the reason but I don't understand why. I had a back pack on the floor next to the vent that was causing it to not breath very well and doing the weird reving after letting off the peddle. Moving the bag and letting it cool down made it stop.
    Also happened one other time when I could hear the battery fan blowing loud. I think it was just super hot that day and needed to cool off.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Yep. This is a known cause and is in the owners manual. Not only that, but I mentioned it as my first suggestion in this thread. Glad it helped you.
    kevtan likes this.
