Engine revs when letting off the gas
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Al Rudolph, Jun 23, 2025.
Tags:
  1. Al Rudolph
    Al Rudolph New Member
    I'm hoping someone can help diagnose or confirm a possible diagnosis. After accelerating to get up to speed and letting off the gas, we can hear the engine continue to Rev. This happens even though the dash MPG reading goes to full 100 (and of course speedometer goes to zero). Is this an issue with the car's main battery? Are there bad cells or will the whole battery need to be rebuilt?
    52,891
    Yes, that is usually the case.
    The whole battery never goes bad all at once, but you need a Prius aware scanner or something like Dr. Prius app to find the bad cells.
    There are procedures you can find if you search here to replace bad modules and rebalance the battery, but be aware that all the modules are old and you will likely be redoing it at regular intervals.
    We call it whack a mole.
    How many miles on her? It could be under warranty
    Al Rudolph likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,637
    2,434
    Left Coast
    You need to look at your traction battery SOC. That's normal operations when the traction battery is low.
  4. ChapmanF
    19,056
    If the dash MPG reading goes to full 100, then the engine is being spun without using any fuel. The car can do this for totally routine reasons that don't have to mean a problem with anything. Can you give more details about the setting where this happens? What speed are you accelerating to, and is the road at that point level, uphill, or downhill?
    Can you clarify this point? I thought you had just accelerated up to some speed X and then let off the gas, so I would expect the speedometer to still be showing roughly X. Do you mean it is slowly decreasing back toward zero as you proceed after letting off the gas?
    When the traction battery is low on charge, the engine may continue to run, using fuel, in order to add charge to the battery. The MPG gauge will reflect that.
    When the traction battery charge is high, the engine may continue to be spun, without using fuel, in order to avoid adding more charge to the battery. From the observation of the MPG gauge going to 100, this sounds more like the situation.
    The temperature of the battery can also figure in.
    Al Rudolph and Brian1954 like this.
  5. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    Can you please explain how a vehicle accelerates up to speed only for "...speedometer goes to zero." You're literally saying that your car is driving down the road and not going anywhere? And granted by that description you'd get unlimited miles per gallon, but that's not reality.
    What's more, when you take your foot off the gas the engine stops revving it doesn't keep revving unless your floor mat is holding the accelerator down... Because you didn't say you're experiencing unintended acceleration, just engine revving when you take the foot of the gas, you're describing a symptom that has never been described before.
    Lastly, this has nothing to do with the hybrid battery. Get an OBD2 reader and Dr. Prius app if you want to know what going on with that.
    #5 PriusCamper, Jun 24, 2025
    Al Rudolph and Grit like this.
  6. bisco
    52,891
    Sounds more like unintended non acceleration
    PriusCamper likes this.
  7. ChapmanF
    19,056
    Because a Prius "gas" pedal doesn't have any direct connection to the engine throttle, all kinds of things can happen when you back your foot off. The engine can rev lower, or stay about the same, or rev higher. Consider what happens when you've been accelerating above your cruise control set speed, say, and your battery charge is high.
    In some situations it's quite normal for the engine to rev higher as you back off the pedal.
    The "speedometer reads zero" part was weird, I agree, but I suspect the OP just meant to say something else and it came out that way.
  8. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    I think they meant the the engine RPM's go to zero.
    could it be the OP is mistaking the a/c compressor for the engine? Try turning off the a/c.
  9. bisco
    52,891
    very possible, some of them sound like machine guns
  10. PriusCamper
    13,475
    5,441
    Well then... If that's really true it must be a barely noticeable type of rev because after 200K miles in a Gen2 I've never heard a legit rev as described. Of course maybe because I was a kid in the 70's revving an engine means something entirely different to me? :)
  11. ChapmanF
    19,056
    Try something like this:
    Set your cruise control at a low speed, say 25 mph.
    Drive faster than that, using the go pedal. Take a descent long enough to bring the battery up to 75% SoC or so.
    Back your foot off the go pedal. :)
    You can watch rpm on an obd device too. You may hit 4500 or so. Should be able to hear that even if it's not exactly what you remember from the '70s.
    Or just search up some of the existing PriusChat posts from people who were new owners and posted questions like "I'm going down this hill and why does my engine rev up when I give less gas and quiet down when I give more?".
  12. Al Rudolph
    She has 86000miles. We bought from a family member. No warranty. Thanks for info!!
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I always heard unintended revs were due to dirty throttle plate.
  14. ChapmanF
    19,056
    The car controls the engine revs based on a variety of things.
    The car is doing different things when the engine revs high with fuel supplied (a relatively low MPG display) or when it revs high with no fuel supplied (a pegged-at-100 MPG display).
  15. Eddie25
    503
    213
    MI
    When I come to a stop mine sounds almost like an engine revving down. It's honestly a little disconcerting since I don't recall having noticed it before and my a/c doesn't seem quite as powerful as it has in years past (although that's a difficult claim to make).
  16. bisco
    52,891
    i have read that people find them noisier just before they blow, but it is perception and anecdotal
