Engine revving high, transmission slipping - 1st gen Prius
Discussion in 'Generation 1 Prius Discussion' started by michael_, Sep 30, 2019.
  1. michael_
    michael_ Junior Member
    Victoria, BC
    2001 Prius
    I just bought a 2001 Prius with 116k miles, and not 3 days later, the dash lit up with various error lights, accompanied by some weird behaviour. Basically, the engine suddenly starts revving really high, while the transmission begins slipping, like it's just barely engaged, transferring very little power to the wheels. I made it home, slowly crawling along the side of the road with the hazards on. Another symptom during a couple of startup attempts had all the lights/screens start flashing wildly.
    Hoping someone can recognize what might be causing this. I'm worried this car is going to end up a total loss.
  2. ChapmanF
    18,980
    Well, there's nothing inside a Prius transmission that can slip*, but there is something that can feel like slipping, when the car isn't able to use the normal amount of electric power in the mix, so the small gasoline engine has to rev unexpectedly high and supply the bulk of the power.
    That can happen either because of a problem in the traction battery, or a problem in the power electronics (the "inverter", the silver box sitting above the transmission). Overheating of either one can cause the electric power to be protectively limited, too. Overheating of the inverter can be a symptom of an electric coolant pump that fails.
    You want the trouble codes from the Hybrid Vehicle computer, which will tell you which of those things might be going on. If it gives you codes about the battery, then you also want the codes from the battery computer, which will be more specific.
    None of the likely problems will turn out very hard to fix; the coolant pump is a small wad of cash, but not hard to swap, and if it's the battery, that's a larger wad of cash, but also not a hard job to swap.
    Everything starts with knowing the trouble codes.
    *ok, there is one thing that can slip, not really inside the tranny but between it and the engine, but it hardly ever does, and if it were, you'd be smelling hot-foundry smell like when people burn out their clutches or brakes.
  3. michael_
    Victoria, BC
    2001 Prius
    Thanks for the info. I ended up finding a local Prius taxi mechanic who had a donor battery from a totaled gen 1 that had just been replaced by Toyota only a year prior. That solved the problem, and I'm hopeful it won't crop up again for another 100k. Is that being overly optimistic?
  4. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
    Not overly optimistic, but lucky indeed
  5. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    If it is as described, you should be good. You're going to want to get set up with an OBDII reader. The easiest is to buy a bluetooth device that plugs into the OBDII and then download one of the smartphone apps (Torque is popular). There's also an app called Dr Prius that will test the battery's health.
    You should also confirm that the inverter coolant pump that Mr. Chapman refers to is working - your mileage is around the age when they fail, and it would burn up your inverter if you kept driving - although you should get all those Check Engine lights and the engine dying if it did. However, I wouldn't be surprised if it hadn't already been replaced, since they've replaced the battery.
    The unit is bolted to the frame behind the driver's headlight. Small electric motor with two in/out fluid lines connected. The original has a black painted bracket and the newer ones have a bare metal bracket. With just the key on, you should be able to see the coolant circulating in the reservoir - it's the narrow rectangular reservoir back/center of the engine compartment, just left of the inverter and right of the brake fluid. You can also squeeze your hand down to it and feel it running and maybe hear it. Little bit of a PITA to replace because of the tight fit, but no special tools or skills required. Some talk about having to bleed the lines after replacing, but I've always pinched them off with vice grips to not lose fluid, and they work fine went I put the new one on. Part is about $130 online.
  6. michael_
    Victoria, BC
    2001 Prius
    No check engine lights are on currently. I do hope they will come on when the inverter coolant pump does go. I called the local Toyota dealer, and my VIN turned up a service record from the owner before last. I have yet to get a copy, but she didn't see any mention of a pump replacement in the list, so probably never has been done.
    I just ordered a $4 OBDII reader from eBay. Hope it's the real deal. Kind of shocking how cheap they are.
  7. ronlewis
    1,059
    205
    texas
    2001 Prius
    "overly optimistic" - not if the battery is as advertised. You can get the manufacturing date from numbers on the case, that'd tell you how old it really is, unless it's an old case that someone has used to rebuild with newer cells. The labels also vary - I'm not sure exactly how, but I think newer batteries have three big labels and the older ones just have one.
  8. ronlewis
    1,059
    205
    texas
    2001 Prius
    Like I said, just look and feel. You should get a CEL if it goes out, but it's so easy to monitor. There's write-ups here on replacing it. I just squeeze some vice grips on the incoming hose to close it off, then swap in the new one and I've not had to bleed it at all on the few I've done. The pain is getting to it - gotta take off the front bumper on that side (let it hang out of the way), and the headlight. Then getting the squeeze clamps off are a PITA, unless you have the special pliers. But it can be done.
