Engine Revving
Discussion in 'Gen 3 Prius Technical Discussion' started by ann gwin, Aug 30, 2019.
  1. ann gwin
    ann gwin New Member
    nashville tn
    Engine has begun revving after acceleration has reached desired speed. Not going faster, just continuing to rev for several minutes. Dealer finds no problem. Any of you had this issue? Any ideas about how to correct it? Thanks.
  2. PriusCamper
    PriusCamper Senior Member
    13,444
    5,428
    Pacific Northwest, USA
    While your situation might change, currently that's normal and simply means your car is having a losing streak in driving conditions for fuel efficiency, which is perfectly normal as long as it stops happening after driving conditions have changed.
  3. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    When this happens, look at the dash display, see if the battery meter has dropped a few bars.
    If so, then it is the engine charging up the high voltage battery.
    This may occur after starting up and driving right away. The drive will
    use battery power for the most/all part until the engine goes thru its warm up stages.
    Moreso after the HV battery ages.
    Has it been properly maintained?
    Might want to check your 12v aux battery for resting voltage or load test. Age?
    Might want to check your air filter under the hood, just in case.
    Might as well check your oil dipstick to be safe too, if the service has maybe forgot a few things?
    Who is doing the regular service?
    How many miles? Are you original owner?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I think this is the most likely answer. And it is more likely to happen if the A/C is going full blast.
    OTOH, if your HV battery starts spending most of it's life with the charge in the lower half of the range.......it might be an early sign of a failing HV battery.
    Just keep an eye on it for a bit.
