Engine rpms stay high after pedal release, mpg way down.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Joecasciojr, Jul 6, 2017.
  1. Joecasciojr
    Joecasciojr New Member
    Connecticut
    My Prius has been sporadically acting up in the following way. When I accelerate, the engine rpms go up more than usual, and the acceleration is not up to par. Then, when I let off the gas pedal, the engine rpms return to idle slowly, rather than immediately. All this is accompanied by a big loss in gas mileage, like 25%.
    But then, just as suddenly, all will return to normal. I took it to my dealer, and of course, it wouldn't do it for them. Anyone experience this behavior? It's as though the transmission is slipping.
    51,155
    welcome!
    very unusual behavior. anything we should know about the car? how many miles on her?
    first rule of thumb here is to check the 12v.
    Mendel Leisk and Raytheeagle like this.
  3. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    Just a guess and hopefully the experts will chime in soon but maybe a dirty throttle body? Seems like maybe the throttle is sometimes getting stuck or lagging.
  4. Joecasciojr
    Connecticut
    Nothing unusual. Only about 40,000 on it.
  5. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    What is the state of charge (SOC) of your traction battery during these incidents? The ICE will be more involved when the SOC is 3 or less bars.
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    I would try to clean the throttle body first, also check engine air filter as well. If there's no check engine light, its mostly mechanical issues. If there's any sensor issues or ecu issues, it will pop up a CEL sooner or later.
  7. Joecasciojr
    Connecticut
    Hmmm... Possibly. But would that explain the decrease in acceleration power vs. RPMs?
    The dealer checked it all over, including the air filters and the computer, no codes were thrown. Puzzling.
  8. Joecasciojr
    Connecticut
    Thank you. I'll mention that when I bring it in again. I guess I'll just have to wait until it exhibits this behavior continuously. They checked the air filter and it was ok. Also checked the computer for codes and there were none.
  9. Mendel Leisk
    40,586
    I'd second checking the 12 volt battery's condition. I always disconnect the 12 volt when doing brake work, and I notice subsequently, just for the first one or two drives, it'll do odd rev-up, like it's recalibrating something. Might be a failing 12 volt is making this a chronic condition in your car? (n)
    Start with just checking voltage with a multimeter, and then if you want to get more DIY in-depth, something like the Solar BA5 can check it's health. Most battery retailers will have something similar but pro-level, and will do a check for free. Or the dealership, for a "modest" charge.
  10. NutzAboutBolts
    1,601
    1,691
    Bay Area
    you can clean the throttle body yourself, it takes less than 15 mins. We also have a video on our YouTube channel so you don't have to pay the dealership to do this for you. Save yourself some money :)
  11. GasperG
    GasperG Senior Member
    1,168
    599
    Slovenia
    2018 Prius
    I have exactly the same behaviour when the battery was too hot or too cold to cooperate, when lift of the throthle the engine slowly goes down with rpm.
  12. Kramah313
    408
    322
    Dallas, TX
    The only way it might is if either the car or you are subconsciously compensating for the reduced power with more throttle. But the car running the engine more to charge one of the batteries is a good possibility too. If the battery was hot it could have been a protect mode thing. Not sure.
  13. bisco
    51,155
    weather has been pretty mild up here lately.
  14. Adrien Prevost
    Adrien Prevost New Member
    Los Angeles
    Hi there,
    I have a 2010 Prius with 117,000 miles and for a couple months now I’m having the same weird issue. I was wondering if you figured out why your Prius was behaving like it did?
    Thank you!!
    Adrien
  15. Drowsychicken
    Drowsychicken New Member
    Acworth GA
    I am having the same issue on my 2011 Prius. Any updates on what the issue is caused by?
  16. Welshdog
    Welshdog Member
    181
    38
    Austin, TX
    Seeing similar behavior on our 2010 Prius with 97k miles. Engine RPMs sometimes stay high after releasing pedal. Gas mileage is lower over last couple of months. Engine is also using oil, but that apparently is normal for Prius models of this age.
  17. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    My sister just called me saying her 2010 is doing this. On my way to check it out. We already replaced the engine. the engine doesn't have many miles. I think it might be overheated battery
  18. JC91006
    16,674
    8,519
    If she's blasting the ac and the soc is low, you may experience this problem
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Yeah she had the ac blasting, but she said the battery was at 4 bars. She also said the engine is ideling in park, but not even charging the battery because its not low. Odd! Maybe drying 12v? The 12v could possibly be 9 years old...
  20. Kramah313
    408
    322
    Dallas, TX
    It could definitely be the 12V but if the battery temp is high enough (I think it’s around 116 F) the engine won’t shut off to protect it.
    Robert Holt likes this.
