Engine runs most of the time 2012 PiP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Brad Riordan, Jan 12, 2015.
  1. bisco
    51,947
    duly noted your honor.:p
  2. Brad Riordan
    Brad Riordan New Member
    The result was , no problem. The regional guy with local, got into the car with test equipment started temp inside garage 50F+ within 10 seconds engine kicks in. I watch as they monitor their computer. Car ran high rpm for over 5 minutes in the garage still running high when they left with the car. Here's the write up on my copy at pick up in the evening.
    "20599 C/S Engine Running Excessively Test drove venicle with FTS - FTS monitored data list while on test drive - On initial startup engine ran until engine temp reached 130 degrees (warm up request) - Exceeded 45 mph per FTS request and engine immediately started - Engine remained running until engine temp reached 130 degrees - continued driving vehicle in EV mode until range reached 1.5 miles, engine started at this time - returned to shop, engine stopped running when temp reached 130 degrees - vehicle is operating as designed at this time (target engine temp of 130 degrees for monitors/emissions puposes)."
    Drove the car home 2 miles engine running high most of the way. I will contact Toyota directly but I see no light at the end of the tunnel. Maybe a you tube video showing this wonderful car running like any gas car. How many of you plug in owners experience this as normal? Thanks.
    Leaving for two weeks. This is my desktop CPU. home 1/27. However my mobile mail is [email protected] if anyone has ideas. I want to thank all of you for your kindness. If the car had not acted like a standard Prius for so long it would be easier to accept this.
    51,947
    as i said, my engine never comes on if i set the term to 'low'.
    any idea where the temp was set? was the 'auto' button depressed?
    how is 'engine came on with 1.5 miles range left', normal?
  4. Brad Riordan
    I will try that. I have left auto on and temp at 68. Before starting I will put in low and see what happens. Thanks.
  5. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I'm with Bisco. I always have my cabin temp set at "LO" and the fan off. I never use the "Auto" setting, even with the A/C. I guess I'm a bit of a control freak, but I like to set fan speed and temp myself. ;) Even in our "cold" weather here in SoCal, my ICE never started, even with garage temps in the fifties or lower, and outside temps in the low thirties. Thank goodness we are back to normal temps now!:p
    It's not that I never use the heater, which I do when the wife is with me, but then I know to expect the ICE to come on.
  6. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Ditto for me...but up here in colder Bay Area I see temps at least 2-4 degrees lower, :)
    Mike
  7. bisco
    51,947
    sure, rub it in.:cool:
  8. CharlesH
    2,797
    1,163
    Roseville, CA
    Anyone see the irony in how we use ICE as an acronym for a heat-producing device? :)
    (Yes, I am sure that this is ancient history. Sorry about that.)
    #48 CharlesH, Jan 15, 2015
    rxlawdude likes this.
  9. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    When I want EV only, I turn heater off and use seat heaters. This works for me unless I go down a hill immediately after starting, or press the gas hard, or go faster than about 45 mph.
  10. rwatt
    rwatt Junior Member
    33
    Pittsburgh, PA
    2013 Prius Plug-in
    Leaving your temperature at 68° is the cause for the ICE turning on. The FAQ discusses this in pretty good detail. Am I wrong?
  11. bisco
    51,947
    nope. the question is, i think, why wasn't the engine coming on with the temp set at 68 for the first (18 months?) of ownership?
  12. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    But didn't the poster admit they may not have noticed the ICE running in previous years' cool season?
  13. GregP507
    GregP507 Senior Member
    3,002
    481
    Open a window in summer; dress warm in winter. Problem solved for the mpg-obsessive.
  14. bisco
    51,947
    i've lost track, but if true, problem solved?
  15. rwatt
    rwatt Junior Member
    33
    Pittsburgh, PA
    2013 Prius Plug-in
    me thinks so
  16. bisco
    51,947
    if you re read the o/p, it says the car worked fine in montana at 15 below zero.
  17. bisco
    51,947
    he does say, if it did it before, it wasn't as loud, so maybe he didn't notice it. maybe he's thrown an engine mount?
  18. rwatt
    rwatt Junior Member
    33
    Pittsburgh, PA
    2013 Prius Plug-in
    fair enough, but I don't get how you couldn't hear the engine warm up in Montana in the winter with the cabin heater on. I'm in Pittsburgh, and I can definitely hear the engine come on when you have the cabin heater on in single-digit weather. Maybe turn up the stereo.
  19. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Not likely. The electric seat warmers are very efficient and are very likely to be more efficient than "waste" heat from the gas engine. Even though the gas engine is "co-generating" power into the PiP battery, contributing to moving the car, and warming the cabin there will still be a lot of wasted heat escaping into the surrounding outside air. Also, the waste heat sent into the cabin is mostly wasted -- it is warming up the steel and plastic inside the cabin in addition to you.
    This will almost certainly represent far more than the ~45 Watts cycling on and off that it takes to warm only your buns.
    #59 Jeff N, Jan 16, 2015
    3PriusMike likes this.
  20. bisco
    51,947
    the problem with running the engine to heat the car is efficiency. for trips within ev range, there's a lot of warming up, a lot of pollution, a lot of very low mpg's and very little heat.
    rxlawdude and Jeff N like this.
