Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Easier than if the eng and trans were still in but still a ways to go.
  2. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I thought I was going to be able to remove the trans under the inverter but now that I see how heavy the trans is that will not be happening. Must remove everything unfortunately. I hope this thing makes it back together.... damper disk was a no go and I'm getting refunded for it. Now to find one without spending 500
  3. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Trans
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Is it not possible to remove the trans by doing the following?
    1, Disconnect inverter from transaxle.
    2. Remove passenger axle.
    3. Hook lifting assembly to trans
    4. Undo trans mounts and driver axle.
    5. Shift trans toward passenger side and lift out of the top,
    I know this probably doesn’t encompass all that is needed to get the trans out, but it’s got the major things that should be holding it in.
  5. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Yeah I will have to strip everything off of the trans.
    I need to find a damper.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    With all of the listings on eBay for a Gen 3 flywheel, I’d reach out to one of the sellers and ask if they have the damper available.
  7. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I don't know that this thing will ever go back together..... trans out. Gotta get the new one in. Then find a damper. Then install engine
  8. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Pic
  9. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Can you install the trans on the engine, then install them together?
    Or is there not enough room?
  10. Mendel Leisk
    42,381
    Did you find the proper part number, for the damper? Is it considered part of the engine or transaxle?
  11. Mendel Leisk
    42,381
    Ok, item 31270 on this page:
    TRANSAXLE ASSY, HV OR FCV. For 2010 Toyota Prius Hatchback HYBRID | Toyota
    And info here:
    2010 Toyota Prius Hatchback HYBRID Damper assembly, transmission input. Fcv, driveline - 3127047060 - Genuine Toyota Part
    DAMPER ASSEMBLY, TRANSMISSION INPUT - p/n: 31270-47060
    A mere $906 on the above site. And at McGeorge:
    Damper Assembly Transmi - Toyota (31270-47060) | McGeorge Toyota Parts
    Discounted price is $597, ugh...
    Pretty sparse on EBay right now, one (new?) for $454:
    31270-47070 Toyota Damper assy, transmission input 3127047070, New Genuine OEM P | eBay
    Some info attached on removal/install, don't see anything on rebuild, as yet:
    #211 Mendel Leisk, Feb 18, 2019
    SFO and Raytheeagle like this.
  12. Mendel Leisk
    42,381
    @Jamesmlemay does the engine turn over easily, say if you've got the spark plugs out and have a socket, extension and ratchet on the crankshaft? Apologies if this is old ground; I'm just wondering how and why that damper seized. Hopefully the damper failure is not the end result of further engine problems.
  13. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    If i recall correctly, He determined early on that motor spun freely by hand.Had to play some catch up on this thread. For some reason the forum stopped notifying me of updates on this one.
  14. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Got the trans in.. realized the black thing in the photos was broken or I broke it.... I have the other one off my old trans but I am afraid they are not in the same position.....
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    That’s the park lock actuator I believe.
    Raytheeagle likes this.
  16. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Yeah I agree. I'm afraid that the two may be in different positions though. So if I put my old one on the new trans it mat not work properly.
  17. qettyz
    qettyz Active Member
    181
    208
    Finland
    Umh, was those bolts capped in such way that they were little bit difficult to remove? I remember from weberauto (youtube) gen3 video that there was some part(maybe parking paul) what should not be removed and it had capped bots. Reason was that it then requires dissamble of whole transmission to get it back. I really hope thats not same part in your pics :S
    Edit: oh never mind, i remembered wrong. Its just safety thing maybe to not remove it because it frees the park paul lock.
    16:00
    #217 qettyz, Feb 25, 2019
  18. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I think that once installed and power is applied to it, it will reset itself to proper position.
  19. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I saw the notification of your post in my email. My stomach dropped. I tried to verify for a while but then decided to come read the post. That's a relief.
    kc5dlo likes this.
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    You can email THE subject matter expert. John Kelly of the Weber Auto channel on YouTube. I emailed him when I was doing my engine swap. He can tell you for sure.
    SFO and kc5dlo like this.
