Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. qettyz
    qettyz Active Member
    181
    206
    Finland
    I'm very sorry about that, luckily i remembered totally wrong. Should really go back and read what i try to remember before scare someone;)
    Jamesmlemay likes this.
  2. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Progress, I think.
    RMB likes this.
  3. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    It’s less taken apart then it was the last time you posted. So, yes, this is progress.
  4. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Engine is in. I attached a photo of hardware I don't know the home for. I believe they are all related to the trans. The 2012 damper was a little different but I put it in anyways...
  5. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    As long as the damper fit the flywheel, and the splines on the transaxle shaft, and the shaft is in the damper, I think you will be fine.
    I would, before attempting to start it, get all hooked up, then with front wheels off the ground, power button twice, shift to neutral, and spin the crankshaft pulley with a socket. If the wheels turn, that verifies crank is connected to transaxle thru damper.
    Or you can just put it back together and go for it.
  6. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    The I dents on the outside rim of the damper went the opposite direction. Originally it indented towards the fly wheel indents. The new one did not. It's all bolted up so I have to assume it connected
  7. qettyz
    181
    206
    Finland
    Btw. How much does used engines cost at USA?
    I looked local used engines and for example found 2015 gen 3 with ~30k miles for 1500€, inverter 500€ and HV battery 1000€ from same wrecked car. Seems that there is no need here for those, since i think those are sold quite nice price.
  8. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    All is well
    #228 Jamesmlemay, Mar 10, 2019
    kc5dlo, mjoo, cnc97 and 1 other person like this.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    That’s a relief. I was going to be upset if it didn’t run after all of that.
    kc5dlo likes this.
  10. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    You're telling me. It was spinning over and not starting at all and making a horrible noise. I figured it was the different plate or something. I made a post here saying it didn't work. I'm done. Lol. Then about ten minutes later I tried it again to record the noise and it ran quiet as can be. That is why my all is well post was edited. Drives nice too
    kc5dlo likes this.
  11. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    If I remember correctly, You sort of gambled on the purchase of the car.. After it is all done now, do you feel it was worth it?
  12. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    No I would have just went out and bought one for the same price or less. Lol I bought it as a car that runs and drives. From copart
    kc5dlo likes this.
  13. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Registering it Thursday finally. Lol. Glad to have my garage back. Or at least starting the garage recovery.
  14. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    100 problem free miles so far. Although at about 25 mph I have a rotational noise that resembles poorly worn tires or bad wheel bearing
  15. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    2500 problem free miles.
  16. Palipride
    Palipride New Member
    Hey I am having the exact same issue I changed the trans due to the damper being broken.
    When I came to start it turns the motor but immediately dies.
    Any ideas?
  17. PriusCamper
    PriusCamper Senior Member
    13,284
    5,366
    Pacific Northwest, USA
    Something is wrong with your engine... In a regular gas-powered car this problem would show up as turning over the starter and the engine never firing up. The Prius is different in that the engine is being turned by the electric motor at a much higher speed to start it, but it won't start, so the motor doesn't really die, because it never was started in the first place.
  18. Palipride
    My engine is turning tho the crank pulley turns mg1 is turning the motor but it won't turn over I understand but what could probably be causing this?
  19. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    You should have codes stored since the engine is spinning but not starting. The obvious question is how much fuel does the gauge show. If it’s at one bar, or flashing, you need to add at least 3 gallons and try again.
    If you have more then 2 bars, or adding fuel doesn’t fix it, the crank sensor or cam sensor, or the fuel pump has failed. There would be codes stored for the sensors.
  20. Palipride
    Only code is p0335 crank and cam sensors changed.
    Gas Over half full and the fuel pump is working fine I disconnected the line and upon ignition it shoots up strong.
