Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If the code is cleared, and resets on the initial attempt at startup, it would be a safe assumption the sensor is bad. Or the wiring is the issue between the sensor and the ecm. You would have to find the diagnostic tree relating to the code that set.
  2. PriusCamper
    PriusCamper Senior Member
    13,476
    5,443
    Pacific Northwest, USA
    deleted
