Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    The MG2 also never spins. Although maybe it is not supposed to. I do not know enough about it.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    MG2 has to spin. That is the motive force that causes the car to move. MG1 is the starter/alternator
  3. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    It won't for me
  4. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If this data is pulled during an attempt to start the ICE, then yes, 0 RPM is right. 4200 + or - on MG1 equates to 1000 - 1200 ICE RPM, which is a start attempt.
  5. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Yeah I attached them on page six. MG1 does spin up.
  6. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Previous owner complained of a shimmy while accelerating..
  7. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Busted damper or flywheel I'd guess. But ICE extraction required to verify.
    Jamesmlemay likes this.
  8. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I hope I am reading the data correctly... I need to watch more videos about the system to see if the mg1 can even spin without the ice spinning under normal conditions?
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    It would be interesting to see what happens if you reach 42 mph on a drive.
  10. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Why what would that do? I should have no problem doing that as the battery is fully charged? I am not sure how capable it is on just the battery....
  11. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    That is the max speed available electric only. That should spin the ICE. Or show you the damper is broken.
  12. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    It will probably drop out of ready actually. I can only drive it until it completely errors out.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Or wide open throttle from a dead stop in power mode. Either of these actions should show if the damper is broken.
  14. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    toyota docs show previous owner complaining about rattling underneath car and steering wheel shimmy under acceleration.
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    This sounds more and more like a damper/transaxle issue. But it’s either drop everything out the bottom, or pull ice from the top, then try and pull transaxle out the top afterwards. The good news(if you can call it that) a car-part.com search shows them as low as a Ben Franklin. But that is a lot of work to do. Especially on a car that you haven’t heard the ICE run yet.
  16. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    If the MG1 is the component that spins the motor to start, And if the MG1 spins but not the motor, it would seem to me that the connection is lost between the 2. Further, I once owned a '72 Chevelle that had a cracked flexplate/flywheel and it vibrated violently on acceleration. Also I could picture the crank position sensor fault if the ecu is expecting the crank to be turning when it is not.
    I must say though that I am not a mechanic. Hoping that you are zeroing in on the problem and the solution. Good luck
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
    So, if we power up by keeping foot off the brake and pressing power twice, are we able to clear the codes and have them stay clear? Doing it this way will ensure the car does not try to go ready or try to start the engine. If the codes clear, and stay clear, then foot on brake and press power to have car go to ready and it will try to start. If MG1 spins to start the engine, but engine doesn't turn, I'm sure the code would return since there would be no CPS signal. As mentioned previously, that pretty much narrows it down to a major mechanical issue at dampner/flywheel area.
  18. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Looks like the drive line has to come out.... got some research to do.
    Cnc97. When you tried starting it with the sensor unplugged, I wonder if the mg1 was spinning
    kc5dlo likes this.
  19. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    When I unplugged my CPS, I could tell the engine was spinning. There was just no spark. Not trying to be a jackwagon, but if you hear the sound a Prius engine that starts like it’s supposed to, versus yours, is there a difference on that noise?
    I have tried to time the response from power button to ICE running on my car, and it’s 1-2 seconds at most. Your techstream screenshots show 4-5 seconds of MG1 on time to the engine stop request. It makes sense that your car would “request” an engine stop due to not seeing the CPS signal.
    The question is where is the failure in your driveline. I have searched this page and there are only a couple of threads on the whole site that even touch on the idea of transaxle damper noise/failure, and the O/P of those threads found the noise to be self inflicted. So did the M/G1 shaft from sun gear to damper fail or maybe the planet carrier? Can you just pull the ICE, and disassemble and repair that with the transaxle sitting in the car? Should you drop the entire subframe and change the entire transaxle as a unit? These are the unknowns, as this is likely the first documented time on this site this type of failure has occurred. I wish you luck, but I hope I never find myself where you are now good sir.
    The WeberAuto YouTube channel may be your best friend right now. They have several videos dealing with the Prius transaxle.
  20. qettyz
    qettyz Active Member
    181
    208
    Finland
    Hopefully this helps (54:20)
    There was a screenshot where MG2 revs are 0 and MG1 over 4500. This tells that vehicle is not moving(MG2 0) and engine is being tried to start by MG1.
    At that state engine should be rotating, only way not to rotate is that clutch damper is slipping. That damper is to made slip under heavy load to protect. My bet is that one is problem?
    And if you can move car in EV mode, then MG2 is rotating. Car cannot move without MG2 being rotated.
    #140 qettyz, Dec 29, 2018
    kc5dlo and Raytheeagle like this.
