Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Thanks all. I actually commented on that video and Weber also believes I have an internal failure. I will pull the motor. Not worried about that just need to find the best way to do it as I never have on one of these. I've swapped motors in a Nissan armada and many vw rabbits/things of the like. I'm working on the ground in a small garage. I don't see coming out of the bottom and option.
  2. Mendel Leisk
    42,381
  3. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Realistically speaking, I had the motor out my first time in just a couple of hours. Just make sure to remove the water pump. You cannot clear the subframe with the water pump installed.
    RMB, amos, Mendel Leisk and 1 other person like this.
  4. qettyz
    qettyz Active Member
    181
    208
    Finland
    That is really great that John weberauto@youtube also replies to comments and helps out.
  5. Mendel Leisk
    42,381
    There's a few removal steps in @Ragingfit 's videos that are maybe not necessary. He spends a lot of time fighting with the EGR circuit removal, for example, and I think you could pull the engine with that still on. Ditto for the exhaust manifold: I think that could remain bolted to the engine, just disconnected at the exhaust end.
    amos likes this.
  6. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I took the exhaust manifold off mine due to close proximity to the windshield. It is cold outside and it wouldn’t take much to crack the windshield.
    amos, mjoo and Mendel Leisk like this.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    He told me in an email he was sure the short blocks are the same. He’s the SME in the topic so I took him at his word on my swap.
    RMB, qettyz and amos like this.
  8. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
  9. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    amos, cnc97 and Raytheeagle like this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I can tell you, the curved lower hose pipe, between the harnesses entering the inverter, there is a 12mm bolt. It secured the pipe to the transaxle. That will allow the hose to come off a lot easier.
    amos likes this.
  11. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Thank you. I'm done for the day. Maybe I can work on it tomorrow. If not won't be until the weekend. Also can't get the exhaust manifold off.
    amos likes this.
  12. Mendel Leisk
    42,381
    I'm purely an armchair mechanic here, have never done it, but if you can just disconnect the exhaust manifold from the exhaust flange, I believe you can pull the engine. Also avoids the need to remove the EGR, prior to engine removal.
    @cnc97 has cautioned: it's really close to the windshield, maybe push some pipe insulation tubing over the lower edge of the windshield, and just take it real slow.
    Too, as soon as you start lifting, I think you can also bring it forward a bit?
    amos likes this.
  13. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Yeah I already pulled but exhaust manifold bolts and one that the manifold just bolts to a bracket with. Still wouldn't budge. I didn't think I'd have room to remove it with it on.
    amos likes this.
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If I remember correctly there were three bolts on the heat shield, five bolts on the manifold to block, four on the bracket (two in manifold and two in block) and the two at the converter inlet. Spray lube on the two hangers and slide them off so the exhaust will drop off the flange. Make sure you have a nut or two on the manifold-to-block or the manifold will hit you in the face. Ask me how I know. LoL
  15. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    Any update? Getting really close to to cause and I'm super curious.
    Jamesmlemay likes this.
  16. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Isn't this the point where I never come back to the forum? Just kidding that's the worst. Unfortunately I didn't get to it this last weekend. It will come out this weekend instead. I will be back. Hopefully with information.
    kc5dlo, Raytheeagle, cnc97 and 2 others like this.
  17. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Finally getting back to it. busy week
  18. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Hopefully you find something that can be easily repaired. Best of luck.
  19. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I didn't have any luck.... I spent an hour assembling my engine hoist. Spent another hour or so continuing disassembly. Right now I am stuck on getting the egr and items below off or getting the donut gasket separate. My car has a lot of corrosion. I'm afraid something is going to break. Three belly pan bolts broke....
    On a good note, I fixed the 02 sensor on my girlfriends jeep after.
  20. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    All you can really do is spray rust penatrent on the nuts and bolts and let it soak, several times.
    Hopefully that will break the rust free. Maybe apply a torch to it and the heat will break them free.
    But it will take time.
    But at least you ended the day with a fix on the jeep! :)
    mjoo likes this.
