Engine seized? 118k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Jamesmlemay, Nov 30, 2018.
  1. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I think I was misunderstanding how the egr disconnected from the manifold. I also hope I had missed a bolt on the exhaust bracket. I need to get it out because if I wait too long ill forget exactly how things went... even with my pictures.
    Jeep was an easy fix. Thing always needs parts. We were car shopping for her for a while but decided to keep it a little longer.
  2. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Mine was apart for so long, I felt the same way. But as soon as it started going back together, everything came to me like a flood.
    Jamesmlemay and kc5dlo like this.
  3. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    How do these come off? Reverse torx?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    E8 Torx socket;).
    I have 2: a short one for the particular stud and a longer one for the other studs in the process(y).
    SFO likes this.
  5. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Thanks. Mine is so corroded I could not yell which was welded. The stud or the nut. Got the top one out don't have the right length extension to get the bottom one right now
  6. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    Got it off by using two 3/8 and 1/4 adapters. Everything is off and ready to come out except the fuel line and my fuel line tool is at home. I also need to figure out where I am going to hoist it from. I only found 6 bell housing bolts. Not sure if there is more.
  7. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    If memory serves me, if you unbolt the fuel rail from the head, it will rotate down, out, and up to the driver side and be out of the way. This is without undoing the fuel line.
    As for bell housing bolts, the two on the starter cover plate, two just below the water outlet pipes on the head, three along the bottom, and two along the back, directly opposite the starter cover plate.
    As far as lifting it out, I used the transaxle side lower intake stud, and the pulley side lower exhaust stud. You want your cherry picker as close to the engine as possible, as you need quite a bit of height to get the engine to clear the front of the car.
  8. padroo
    padroo Senior Member
    2,763
    2,253
    I don't know what kind of head it has on it but I would double nut the exposed end with the good threads to break it loose.
  9. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    So close to finding out what’s going on with this. It’s the book I can’t put down.
    kc5dlo likes this.
  10. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I suppose it's possible I snapped the shaft pulling it out but I doubt it lol. I'll let the photos do the talking. 20190126_133838.jpg 20190126_133648.jpg 20190126_133643.jpg
    mjoo, Raytheeagle and Mendel Leisk like this.
  11. Mendel Leisk
    42,381
    That doesn't look gud...
    Raytheeagle likes this.
  12. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Damper failure. That snapped the shaft coming out of the transaxle.
    mjoo and Mendel Leisk like this.
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Dang. Does that mean a trans overhaul/new trans?
    Pixel XL ?
  14. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Transaxle is significantly less then an engine. Only a couple hundred. I think you could drain the transaxle, pull the input shaft and replace it. But you would need a schematic to be sure.
    mjoo likes this.
  15. Mendel Leisk
    42,381
  16. Mendel Leisk
    42,381
    Start watching around 54:00, think that's the damaged components he starts discussing:
  17. Mendel Leisk
    42,381
    Might be these:
    Shaft Assembly Input - Toyota (35710-47041) (superscedes 35710-47040)
    Drive Plate - Toyota (13451-37080)
  18. Jamesmlemay
    Jamesmlemay Member
    112
    59
    Maine
    I haven't been able to review your links yet but from what I can tell I would have to disassemble entire transmission to repair.
  19. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    mjoo likes this.
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I believe that if you have this mainshaft, it could be serviced in this way. Possibly.
