Engine shaking vibrating help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ensol, Dec 5, 2016.
  1. Ensol
    Ensol Junior Member
    27
    Uk
    Hi am experiencing engine shaking and vibrating! This mainly happens on cold starts! This also is common when the car drops down to two bars then the ice kicks in! Any ideas?
    Thanks
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Your engine is toast,don't go anywhere far
    52,607
    might need some cleanup work, how many miles on her? does she burn any oil?
    Raytheeagle likes this.
  4. JC91006
    16,892
    8,627
    Bad motor mount? Misfiring?
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  6. Ensol
    Ensol Junior Member
    27
    Uk
    The mileage on vehicle is about 170000! It use to be silent! Now engine is getting violent!
  7. Mendel Leisk
    42,108
    ^ Yes, how's oil consumption?
  8. Ensol
    Ensol Junior Member
    27
    Uk
    Top up every two weeks about 1/2 litre
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Original owner? Ever change the PCV valve? Clean the intake manifold? Does the engine throw any codes? Loss in mpg? How long has the oil consumption been at that rate? Egr been checked?
  10. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Many possible causes. One is something called an EGR valve, which is currently covered under an unlimited mileage warranty!
    NEW!!! Service Bulletin for Engine Knocking at Startup T-SB 0012-10 | PriusChat
    However, another possibility is, if you're losing oil because of failing piston rings, it will cause the EGR valve to become clogged. You or a mechanic can clean this out and bring some life into the car. Some engines with bad rings last a very long time, but with Prius (and probably many others) you need to clean out the clogging which this condition can cause.
    Or it could be something else...
  11. Ensol
    Ensol Junior Member
    27
    Uk
    Hi guys thats for the advice! I think i will start by cleaning the egr valve out and see what differance it makes!
  12. bisco
    52,607
    did you do the plugs at 120k? is the air filter clean?
  13. Rebound
    3,996
    2,645
    Portland, OR
    Cleaning out the EGR valve is somewhat involved, but there's a NutzAboutBolts video which shows how to clean the EGR pipe, and that's very easy. This is the pipe between the EGR valve and the intake manifold. If this pipe is showing signs of being blocked, then maybe you should consider cleaning the EGR.
    Another poster took his car to an independent mechanic who actuated the EGR valve a few times using his diagnostic scanner tool, and this apparently un-stuck his EGR and solved his problems.
  14. Former Member 68813
    3,524
    983
    US
    lets hope it's ERG/intake needing cleaning and isn't a HG. any disappearing coolant?
  15. Mendel Leisk
    42,108
    And how many miles are you going in that time?
    This doesn't sound good, btw.
  16. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Is it every cold start?
    or a cold start AFTER you had previously driven the car a very short distance, say backing it out of the garage and shutting it off?
  17. Qwer
    Qwer Junior Member
    16
    2014 Prius v wagon
    Fix head gasket/ coolant pressure issue in one second: take off the little rubber ring on overflow reservoir cap. The pressure in coolant system will be stable atmospheric. No more 15psi pushing coolant through gaskets etc.
    xerox6135 and bisco like this.
  18. Qwer
    Qwer Junior Member
    16
    2014 Prius v wagon
    Nature of "cold start" issue is accumulating coolant inside cylinder. Too much pressure. It happens 75% of stars, due to random position of the bad cylinder piston
  19. bisco
    52,607
    welcome, and thank you!(y)
