Engine shrudder and Check Engine Light came on.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Tramp, Aug 11, 2010.
  1. The Tramp
    The Tramp Italian Prius Expert
    354
    32
    Turin, Italy
    2020 Prius PHV
    Hello everyone,
    My car has 120.000 miles and regular maintenence done on schedule.
    Yesterday, after a 1000 mile / 4 day trip, after a break at a service station, the engine srudded violently (for being a prius, it felt like a diesel) while cranking up durin acceleration.
    The check Engine light came on.
    Using Can-view, I noted these DTC codes: P0101 C3100 P0000
    And cleared the memory.
    The check Engine switched off.
    Then I tried to to a kick-down: the engine responded normally, but the check engine started blinking. I looked at the DTC codes: P0203 P0401 C3100
    Later tests of acceleration, stopping, etc. did not produce any more errors.
    Today I looked on my Prius technical reference manual but I could not find NONE of the above mentioned codes. :confused:
    Can anyone help?
  2. Patrick Wong
    18,200
    6,474
    Yes, looks like the CAN-View is useless with regard to providing the correct DTC.
    What is a "kick-down"?
    Have you replaced the iridium spark plugs recently?
    If the check engine light returns, I suggest that you visit a Toyota dealer so that the DTC can be read. Good luck.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    have you checked the ignition coils?
    step 1 would be plugs.. 2 would be the coil that isn't firing for that particular plug.
  4. The Tramp
    354
    32
    Turin, Italy
    2020 Prius PHV
    Oh, am I not the only one?
    It's when you floor it, accelerate 100%.
    Recently, no. I've done it at 64,000 miles, next time it's due in 3,000 miles.
    Yeah, pity I am in Danemark and later Germany, the lanuage barrier is a problem. :D
