Engine Shudder w/ check engine light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeff O'Connor, May 25, 2018.
Tags:
  1. Jeff O'Connor
    Jeff O'Connor Junior Member
    Stratford, CT
    Severe ICE shudder, flashing check engine when ICE running, solid on when not. I have an appointment after this long holiday unfortunately...terrible timing.
    I've looked this up, and noticed it happens to folks here and there.
    Just started last night, took it out today for another drive to analyze some more..Still doing it. Sluggish when giving it more gas, eventually revs up, and evens out a bit. Light keeps blinking still when ICE running, goes solid when ICE shuts down at a stop.
    Is it safe to drive a bit like this, or should I avoid driving till my appointment?
    Thanks gang.
  2. Patrick Wong
    18,200
    6,472
    Avoid driving, it sounds like the car is dangerous in its current condition.
  3. Mendel Leisk
    38,653
    How's the oil level? How's the coolant levels? How many miles on the odometer?
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,684
    Texas Hill Country
    I would certainly get a trouble code scan run on it. Some auto parts stores can do the basic codes but you probably need hybrid codes as well. Apparently not starting the gas engine very well would be my first guess. That can be any of your standard gas fuel air ignition issues as well as hv battery discharged or failed. How is the hv battery charge indicator? Very low and staying low? I would probably borrow or rent a car rather than drive this one much with unknown issues. Sometimes a local garage has hybrid knowledge and appropriate scan tools. Call around.
    Raytheeagle likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,196
    5,893
    Columbia, SC
    You are having a cylinder misfire problem. Could be a bad plug(s), injector(s), coil-on-plug or even a large vacuum leak. Maybe even crappy gas. But certainly, a misfire problem. Be aware that misfires that are significant enough to cause severe shaking and a blinking CEL are potentially putting enough raw fuel into the exhaust that it can damage the catalytic converter.
    If you are unable to get codes read, you could probably just buy the cheapest model at Autozone, etc and it would work for you.
    If you dont want to buy/borrow a scan tool: If the spark plugs have more than 80k miles on them (assuming they are iridium/oem) and you're feeling mechanical today, I would probably start with those, as it's needed anyway.
    I believe even a basic scan tool will provide the answer on this one.
    #5 TMR-JWAP, May 26, 2018
  6. padroo
    padroo Senior Member
    2,763
    2,250
    I would avoid driving it but as others have mentioned check all critical fluids before taking it for repairs.
  7. JC91006
    16,478
    8,394
    I believe they mention in the owner's manual, stop driving immediately if the check engine light is flashing
