Engine Sound - Wiper like sound from engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Optimistic, Feb 2, 2023.
Tags:
  1. Optimistic
    Optimistic Junior Member
    Jacksonville, FL
    Hello,
    I was hoping to figure out what the problem is with my 2005 Prius before taking my car in for repair. The weird rhythm clock / clicking noise sounds like the noise in the below video. Similar to a back and worth sound almost like fast windshield wipers. I mostly notice it while the car is stopped in park (does not seem related to the wipers). It does not happen all the time but don't want to wait until a real issue or danger arises before checking it out.
    weird sound front driver side 2005 prius 230k miles - YouTube
    If you know what it is or have any ideas, please respond.
    Thank you!
  2. ChapmanF
    19,020
    Here's one of the threads where we've discussed that noise before:
    3 way coolant valve noise. | PriusChat
    For more details on what's really going on, there's this one:
    P1121 and inside the coolant valve | PriusChat
    The valve shifts between different positions for pumping into the thermos, out of the thermos, or normal engine operation where coolant just circulates through the engine and heater. The valve has a position sensor that reports back what position it's in. Any time (any time, pre-start, post-shutdown, or while the engine runs), if the valve doesn't report being in the right position, the ECM will try to send it there.
    If the valve position sensor is flaky, and never looks like it's in the right position, the ECM will be stuck sending the valve back and forth to try to find the right position. That's the washing-machine noise.
  3. Optimistic
    Jacksonville, FL
    Thank you very much! Looks like a great place to start. It was hard to describe that sound, a washing machine is not one I would have thought of. Will have to research if replacing the coolant valve will cover it. I actually had a coolant flush perhaps around the time the noise started.
    Again thank you very much Chapman!
  4. ChapmanF
    19,020
    When I was a kid, washing machines were pretty much all top-load with agitators, and there was a generic sound they kind of all had.
    Not so much anymore....
