Engine sounds like cold diesel engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mihai Er, Dec 29, 2016.
  1. Mihai Er
    Mihai Er New Member
    London
    Hi guys!
    First time here! I just bought a 2011 Prius (125k miles), i had one before from 2012 (160k miles as a taxi), sweet jesus, bulletproof!!
    When i accelerate (full power),the engine makes noise like a cold diesel engine, but just for a few seconds, then it stops, even i'm still acelerating. Most of the time it's very quiet like new, but sometimes not all the time, when i step on it, that cold diesel sound it's there!
    The car is standard.
    Any ideas?
    Thank you!
    Mihai
    (CARLOVER) likes this.
    52,801
    welcome!
    is the oil level okay?
  3. Mihai Er
    Mihai Er New Member
    London
    Shame on me, i've arrived home. but i didn't check the oil level! last service at 121k, now it has 126k , it shouldn't be a problem, but i will check!
    Thank you for you speed!
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat :)!
    Do you know anything of the maintenance history? How many miles have you put on the car? Any dash lights come on? Do you notice this when starting it up first thing when starting out?
    Keep us posted(y)!
  5. Mihai Er
    Mihai Er New Member
    London
    I got the full maintenance history, last one at 121k miles, the car has now 126k. No light in the dash. I've check the oil today, and i had to put some of it, i couldn't find 0w20 and i had 0w30 (i hope is not a problem). today the car was very silent, but at the traffic light when the petrol engine was charging the batteries, after i put my foot on the throttle ( gentle), the sound was there for a few seconds, it's sounds like a cold diesel engine but i think is a powerful vibration, i think!
    Raytheeagle likes this.
  6. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Did the maintenance history have anything to say about egr or intake manifold work? Are you the DIY type?
    Have the spark plugs been changed? PCV valve? How much oil did you add when you topped it up? How many miles have you put on the car since you bought it (is it 5 k miles)?
    At around 120 k miles is when I cleaned the egr system to the intake system out as I was noticing rough motor to engine transition (maybe your vibration)?
    Keep us posted(y)!
  7. bisco
    52,801
    120k is a big service. can you record the noise?
  8. Mendel Leisk
    42,293
    I notice what might be a similar sound, at certain points in acceleration. A little more or less pressure on gas pedal, it goes away. And it's not a constant thing, just occasional. So far I've just ignored it. Maybe some pollution control kicking in: EGR, PCV?
    FWIW, I've heard this from early days with the car, and now we're only at 65K km's.
    #8 Mendel Leisk, Dec 31, 2016
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    150K?????? If so some have had head issues but most nothing until they can't stand the car anymore.
    The typical rattle is on start up only on a cold engine which Toyota claims is the EGR/manifold issues.
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    In the US, if you do not use 0w20 oil, Toyota says to replace toe oil & filter every 5000 miles instead of 10000 miles.
    See http://www.toyota.com/t3Portal/document/omms-s/T-MMS-11Prius/pdf/T-MMS-11Prius.pdf
  11. Mihai Er
    Mihai Er New Member
    London
    I work as a cab driver, it's very hard for my in that moment to pull out my phone and record.
  12. bisco
    52,801
    gotcha.
  13. Mihai Er
    Mihai Er New Member
    London
    i bought the car 1 1/2 weeks a go! the guy told me that he changed the EGR valve at toyota service (£450), yes that part looks like new. I don't now if he changed the spark plugs. When i've checked the oil, that was bad, so i had to put 1L, and now the level it's exactly at a middle point between min and max. I think i did less then 1000k miles!
    I've notice something, after 120 mile ( no break, i'm a cab driver) no sound, but at a traffic light with my batteries on only 2 lines, being stoped, the petrol engine starts to charge my batteries, when i've put my foot on the gas, there was a transition, and then the sound appeared. This is the only time when the cold engine sound appear.
  14. Mihai Er
    Mihai Er New Member
    London
    YES!! You now what i mean! This week i'll ask my service to fix this problem! my car has 126k miles!
    The EGR it's new, changed at Toyota Service (£450).
  15. Mihai Er
    Mihai Er New Member
    London
    it's only happening, when the petrol engine charge the batteries , with the car stoped! The bad sound kicks in when i step on gas pedal!
  16. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    When this issue has happened state side and the car displayed P0401 as the code, there was an extended warranty for the egr valve only. So all they would replace was the valve.
    IMO I think there is additional carbon deposits in your egr system. An easy way to determine the extent is to remove, clean and replace the egr pipe. There is a maintenance video on how to do this in the Gen3 maintenance section (a sticky thread at the top).
    What gas do you buy? Sounds like the last owner may have purchased low detergent or standard gas. Over here we have "Top Tier" gas which is high in detergents to prevent carbon buildup. If you have only had the Prius for a short period and have not filled up yet, I would recommend finding good quality gas and run it. Potentially some fuel injector cleaner.
    Depending on what you find when you remove, clean and replace the egr pipe will determine next steps.
    Keep us posted(y)!
    Mihai Er likes this.
  17. Mihai Er
    Mihai Er New Member
    London
    is not to much, but let's give it a try! i hope you have some speakers, start at sec 2 till 4!
  18. Mihai Er
    Mihai Er New Member
    London
    i have 2 sec of my diesel sound!
  19. MeGuinness
    MeGuinness Member
    217
    78
    UK
    I'm having the same problem to....It goes away if I unplug the egr valve connection....Try and see if keeps doing it!
