Engine Splash Shield Fell Off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eseerc, Dec 20, 2013.
  1. eseerc
    eseerc Junior Member
    53
    Central PA
    The engine splash shield to my 2010 Prius fell/tore off after ran over some chunks of ice and snow. (The plastic "flap" that folds down to allow access to the oil filter and drain plug.
    My local dealership says I need to replace the entire plastic lining under the vehicle to the tune of $250+.
    1) Does anyone know where I can obtain just the flap? Surly this piece must be available individually
    2) I may not be able to replace the flap for a few days. I assume the Prius is ok to drive without it?
    52,872
    salvage?
  3. toyolover
    toyolover Member
    441
    67
    toronto, canada
    There are threads posted about a year or two ago regarding this problem. Some have modified it themselves while others had Toyota replaced it under warranty. I had mine replaced under warranty by the dealer but it was when the vehicle was one or two years old. Do your forum search here before talking to the service manager again. I heard Toyota made it with better plastic on later model years.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    The 2010 Toyota Prius plastic under body has a TSB on it. I don't know if your dealer would replace the entire piece for you under the TSB or not, it all depend on them.
    As for the missing piece, you can't replace just that piece, its a whole plastic piece.
    And yes, your Prius is fine without that plastic piece, as long as you don't go over a solid rock and damage your oil pan.
  5. kenopa
    kenopa Junior Member
    57
    Indiana
    After numerous oil changes, my flap broke off about two years ago. Vehicle was out of warranty period. I have done nothing about it, nor has any dealer shop recommended replacement. Vehicle still flawless at 83,000. Maybe engine gets a little dirtier because flap is missing. Not planning to run down large rocks in near future. Why worry?
    xpcman likes this.
  6. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    As posted elsewhere I tore my entire under body thingy off running over a large dead Kangaroo at high speed while overtaking a truck. Despite dollar parity at the time it cost $550.00 to replace. It won't harm your Prius to leave it off but I did notice a small spike in fuel consumption while it was missing.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
  8. Mendel Leisk
    42,359
    It'll last fine IF that "oil maintenance" flap is never used, ie: the whole panel is removed for an oil change.
  9. El Dobro
    El Dobro A Member
    7,106
    3,282
    Which is what I always do. :D
  10. Mendel Leisk
    42,359
    I used that flap on my first oil change, and right away it was: "something's wrong here". Tried to bend the flap down, and the entire panel was flexing. Rap the panel with your fingers and it almost sounds like metal, very hard, evidently brittle as well.
  11. El Dobro
    El Dobro A Member
    7,106
    3,282
    That's what happened with me, I didn't like the way the thing bent, so I took the whole panel down and did it that way ever since. Plus, you get to see if there's any nests in there. :p
  12. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Check here, fourth item down, way less than the dealer.
    prius engine cover | Partsgeek.com
    toyolover and frodoz737 like this.
  13. Feri
    Feri Active Member
    761
    144
  14. AishaT
    AishaT Junior Member
    Los Angeles
    I like ToyotaPartsBarn.com. Decent prices. At least better deal than the dealership
  15. toyolover
    toyolover Member
    441
    67
    toronto, canada
  16. Mike500
    Mike500 Senior Member
    2,593
    767
    I got one from PartsGeek.com just to have an extra to experiment with.
    It came rolled up in a long gigantic box. For me, I found out, it was about $49 delivered in one day by UPS since it was shipped from Charlotte, NC, just about 100 miles away.
    The panel is made in Taiwan of vacuum formed textured black polyethylene. Instead of being die cut as the OEM panel is, the panel is hand cut and shows rough edges.
    It is a clone of the older type, NOT the NEWER one with the wide radiused hinge area. It will evidently still need the piano hinge conversion to achieve longevity.
    The panel does not contain any hardware of the insulating panels or anything else.
    I have NOT installed it and will keep it as a spare. It would also serve are a nice pattern for making just the replacement door out of aluminum sheet to be attached with rivets and a piano hinge.
  17. milkman44
    591
    386
    Ky
    Thanks for the update, I'm considering ordering one since my oil change door is missing. I'm just having a hard time convincing myself that the missing door makes that much difference, don't have to fool with it at oil change time. I'm still on the fence as to whether I should order it.
  18. Mike500
    2,593
    767
    You're very welcome!
    If I was in business, I would make and sell just the replacement door with just the piano hinge kit installed.
    The only problem would be some doofus who would complain that the kit is defective, NOT being honest about his or her lack of abilities.
  19. FrankB
    FrankB Member
    117
    53
    I got the partsgeek engine shield for my pre-owned 2010 Prius since it was missing the oil change flap completely. I assume there was an insulating panel on the oil change flap. Does anyone know if that part if available somewhere? I searched partsgeek but did not find it.
    thanks,
    Frank
  20. Mike500
    2,593
    767
    Only Toyota. And, you have t buy the entire engine cover for over $200.
    You can make a shield out of aluminum roof flashing or fiberglass mat, which is cheaper.
