Engine stall after 10 sec.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MaverickCND, Jul 11, 2019.
  1. MaverickCND
    MaverickCND Junior Member
    Toronto
    Engine stalling after 10 sec, Please Help..... my Prius GEN2 -2004 has persistence issue, it starts for 10 sec and engine light comes and red big triangle, etc, and engine stop.
    Read OBDII : P3190
  2. MaverickCND
    Toronto
    thanks so much. I will try these....
  3. ChapmanF
    19,026
    Another "engine stalling after 10 seconds" thread, another clarification on how that isn't what's happening. The engine is cranking for 10 seconds and failing to start. On a Prius, the cranking is fast enough to fool new people into thinking the engine has actually started.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    The OP has this question in at least one other thread.
  5. ChapmanF
    19,026
    I saw you already clarified that one....
    Skibob likes this.
  6. MaverickCND
    Toronto
    I finally get the car running again :) :):):):):):) : This is lesson learnt : Car was running ok, till it suddenly stalling and stop red big triangle, trying to start engine last for 10 sec and gain error message light up, scan code P3190, P0A80. Trying second hand HV battery, still issue, towed to Toyota dealer said HV battery again, try to charged old battery, still P3190, try changing oil, try checking fuse, trying fuel pressure/ pump, ....... few days ago trying to spray starting fluid, car started erratically, clean MAF sensor, clean butterfly valve, now running like a charm.:D:D:D:D:D:D
    Juan Carlos Valle and bisco like this.
  7. bisco
    52,858
    congrats, well done!(y)
