Engine started while changing oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by joedroid78, Aug 9, 2014.
  1. Mendel Leisk
    42,343
    I remember some commercial where they were running engines after oil drain. It's like commercials where a model demonstrates a fridge with the door hanging open, drives the viewer nuts. ;)
  2. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Yes, I remember the commercials for Slick 50. Even tried some of the stuff until Consumer Reports reminded me that teflon only works when it's baked on. You're probably thinking of one of the other scam products like Prolong - they claimed to drain the oil from Corvettes and other high-end sporty cars and drive them on a track at 90 mph for 30 minutes "without damage". Consumer Reports debunked that with a CR segment titled "Don't Try This At Home". Their identical Oldsmobiles made it a only few blocks down the road at 40 mph before seizing up. The FTC sued that one and others for false advertising. But I digress. I agree that a few seconds probably caused no harm. Just don't make a habit of it!
  3. JC91006
    16,936
    8,647
    I had this exact scenario happen when getting an oil change, by my mechanic. He drained the oil with the car in park, while in Ready mode. I heard the humming noise from the inverter and realized he didn't power off. Luckily the engine didn't turn on.
    A few seconds shouldn't hurt much. You have to think when you drain your oil during an oil change, there needs to be a few seconds before the new oil passes through the oil filter. This happens everytime you do an oil and filter change.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Actually, it is impossible to evaluate what damage that incident might of caused.
    6-7 seconds with the oil low, and the engine starting at an "idle" demand?
    My guess would be little to none.
  5. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I find the oil change easy enough on ramps. Not as easy as other cars because it sits so much lower I can't roll onto the other shoulder under the car, not enough vertical clearance. Otherwise basic oil change & the whole cartridge filter was a cakewalk. Just get a quality adapter wrench & it's simple.
  6. michinnom
    michinnom Member
    162
    29
    Best reply to first post ever!
