Engine starting getting more forceful?
Discussion in 'Gen 3 Prius Main Forum' started by kevelev, Nov 11, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    Looks like it really needed it.
  2. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Where do you stand on oil catch cans Ray, bought one a few months back but haven't fitted it yet.
    Has anyone got ant proof they reduce the build up of carbon or is it just wishful thinking.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I have one on our 2010 and mounted it on the lower cross member. I mounted it low so it acts like a true knock out pot.
    I put ours on last winter and cleaned the egr circuit at the same time. My plan is to clean the egr circuit every 50 k miles so next Christmas I’ll be able to answer your question about it making a difference.
    But addin the catch can is something I’d add and check the level often if I were in your position seeing the amount of deposits you are generating.
    taxidriver50005 and Mendel Leisk like this.
  4. kevelev
    kevelev Junior Member
    65
    ny
    This is all really good info guys, and thanks for the photos! I'm trying to get a list of items to address for my next tune-up (engine-related). Feel free to add to it!
    Clean:
    1. Intake manifold
    2. Throttle body
    3. EGR pipe
    4. EGR cooler
    5. EGR valve
    6. Injectors
    Replace:
    1. Spark plugs
    2. PCV
    Add:
    1. Oil catch can? Any recommendations?
    Raytheeagle likes this.
  5. Mendel Leisk
    42,381
    That's a tall order, and tricky. I don't recall anyone here getting into that as yet. Maybe just try adding an injector cleaner at fill-up, for starters.
    If you've got deep pockets the Moroso 85474 is very nice. Maybe chauvinistic, it's what I got.
    Raytheeagle and padroo like this.
  6. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Instead of doing the injectors I’d run some BG Products 44k through them;).
    Think of super concentrated Techron:).
    The Moroso is more coin than required, but that would be effective. I picked up the $38 on Amazon version and it works well for us(y).
    padroo and Mendel Leisk like this.
  7. Mendel Leisk
    42,381
  8. Mendel Leisk
    42,381
    Would you believe I've got a spare Moroso "kicking around"? Son was asking about it, then cold feet. I'll figure out something to do with it. I know: put it in the crawl space with the PIP rims.
  9. Mendel Leisk
    42,381
    RX Performance won this shoot-out, with Moroso:
    It's not cheap either, though. One thing: you can take them with you, from car to car.
  10. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Another addition to the shrine :).
    Hopefully they don’t become relics(y).
  11. padroo
    2,763
    2,253
    I think I finally got rid of all my spare Gen 2 parts except for a new set of rotors on the top shelf in the back of my second garage and I can't get to it without moving cars. I have them promised to a guy I used to work with.
