Engine starts itself at 35 mph in deceleration
Discussion in 'Gen 3 Prius Fuel Economy' started by kensiko, Apr 8, 2013.
  1. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Is it normal? I tried to find a discussion about this in this forum but couldn't find anything.
    When coasting over 35 mph, when the speeds reaches 35, the engine (or ICE as you prefer) is starting for a second then stops. I really don't see why it would do that.
  2. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I've never noticed this. lease include temps, driving time, engine coolant temps etc. when trying to diagnose something like this. :)
  3. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Ok if it's the temperature I'll see what happens during the summer. It was still near 0 Celcius this week-end.
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    On a short trip in freezing temps your engine coolant temp may not have been high enough to keep the ICE off. This is especially true if you had the heater or defroster on! If your SOC was low from gliding then that could have also trigger the ICE to fire.
    This is one of the reasons that hypermilers use grille blocking in temps below 40F. When coasting with the ICE off the engine cools down pretty quickly at higher speeds.
  5. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    ok, but I saw this behavior multiple times and on many occasions the heat was at OFF.
  6. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    But what was the ICE coolant temp? What was the SOC?
  7. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    Where do we see the temp?
    SOC was probably where it is when I go on roads, at (all bars minus 2)
  8. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    You see it with a scangauge. Same with the SOC %. Alternatively you can use the Torque App and a smart phone.
    Without any of this data there is not much than can be said and even less reason to worry about it further. Get the monitoring devices. :)
  9. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    hehe I see. There is no bluetooth on my car so not much to do with a smart phone.
  10. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    It doesn't sound normal to me, particularly if you had the heat off.
  11. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
  12. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    It's still doing it, really repetitive, like a trigger at 43 mph (yes it's more like 43 and not 35). It does it in acceleration too if I'm in a slope. Are you sure it's not doing that for you guys ?
  13. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    Well 43 mph is a different story. If your speed is increasing past 43 the MG1 is forced to get the engine turning to protect the MG2 from overspeed. The engine must be turning once you're above this speed.
    If you're coasting down in speed you're probably feeling a slight jolt as the system allows the engine to stop turning.
    This is very normal and to be expected.
  14. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    43 is normal 42 is the official. over that speed the ICE must be on that is by design so whichever electric motor is no over rotate ..
  15. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    OK but we can turn off ICE over that speed by releasing the accelerator
  16. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    Its normal..., and no the ICE will not turn off until you drop below 43mph (when it is fully warmed up)...
  17. telmo744
    telmo744 HSD fanatic
    2,170
    764
    Portugal
    When doing this, it injects a few drops of fuel for very brief time.
  18. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    That's not was I observed, we can see gas consumption drop to 0 L/100km if we release the accelerator at 60 mph. I can feel it when ICE is starting-up again and the gas consumption bars appear.
  19. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    You won't.
    Unless you purchase an aftermarket device to reveal what's actually happening, it's going to be a lot of hit or miss guessing. Sometimes, the engine actually does start up. Sometimes, the engine simply spins without consuming any gas.
    Bluetooth devices (under $20) that work with a smart-phone app ($5 Torque) can be extremely informative.
  20. szgabor
    993
    175
    Oceanside NY
    How did you observer this ??? I have a SG so I can tell you and others as well that over 42-43mph the engine is turning weather or not consume gasoline that is something different but it will have 996rpm even when 'no power is coming from it' what you may feel is that the ICE puts out power to the wheels ... :)
