Engine starts runs briefly shuts off rattle
Discussion in 'Generation 1 Prius Discussion' started by windrider, Jan 24, 2015.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    If immediately after an oil change it is definitely an overfill. They should fix the problem.
    Can you send a pic of the dipstick level.
    Car off.
    Remove dipstick
    Clean with paper towel
    Reinsert dipstick
    Remove and check level (take pic)
    Empty extra oil.
    Clean throttle body.
    Sop up extra oil off inside top of engine under throttle body.
    Clean MAF since you are there.
    For spraying starter fluid, you can do it yourself. Spray. Jump in and press the power while foot is on the brake. Jump back out and additionally spray as needed.
  2. krnluve24
    krnluve24 Junior Member
    Virginia
    2001 Prius
    I emptied out roughly 3/4 quart of oil so the dip stick reads below max. I cleaned the Tb. I changed the spark plugs. I managed to keep the car running as long as I keep spraying starter fuel. I bypassed the circuit opening relay and EFI relay with two paper clips, no luck. Now it's down to the fuel pump test... It could possibly also be the ecu, who knows..
