engine stop working on the way, car moving on battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Yev Vo, Oct 21, 2019.
  1. Yev Vo
    Yev Vo New Member
    san jose
    on my prius 2008 engine stop working after red triangle show up. car was moving only from hybrid battery till it is drain . after some time i can turn on car and engine will work for 2 -3 minutes and charge battery but then it stops work
    I did not test battery, coolant was leaking 3 days ago, after i took it to mechanic they said that now everything is okay and they add coolant
    Now engine coolant looks like empty, not sure it was dark
    52,742
    welcome!
    how many miles on her? any puddles under the car?
    did they read the trouble codes?
    SFO likes this.
  3. Yev Vo
    Yev Vo New Member
    san jose
    it was camshaft position sensor
    52,742
    excellent!(y)
    (i didn't know coolant could leak out of that)
  5. Yev Vo
    Yev Vo New Member
    san jose
    coolant was leaking not because of that
  6. bisco
    52,742
  7. MalcolmRock
    MalcolmRock New Member
    Virginia
    Question,
    Do you know what caused the sensor to fail? Was it the sensor itself or did the 12V battery need to be replaced because it was not providing enough voltage and was giving a false error.
    Thanks
